Question about Kenmore Washing Machines
Reader showing F1 and makes a very loud noise when machine is in spin cycle. I have a Kenmore Elite-Oasis, model #110-27032602. Type 581. Any suggestions on how to fix? Thank you Aurora Evans
  • emikee42 Oct 07, 2009
    I understand and thank you - would this take care of the problem with the loud noise during the spin cycle? Thank you Aurora Evans
  • 10,515 Answers
With the washer plugged in and all indicator lights off, select any key except power, start and stop.
Press hold for 3 seconds, release for 3 seconds, press hold for 3 seconds, release for 3 seconds, press hold for 3 seconds. If you did it right all indicators will light and 88 will appear in the display. If there are any faults, they will then display, look for a F-60 through 68. This will confirm the board is corrupt. If no faults are found the machine will go through a five minute automatic test cycle.
If it continues through the test mode stop/cancel should stop it from going through the test code.
In brief, it's an issue with Control Board and more likely you need to replace it.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 07, 2009
    Brigadier General:
  • 3,513 Answers
Hi
F1 code = Primary Control Failure. Replace the machine/motor control assembly. If you use a screw driver in front of the machine to open the top you will find a repair manual on the inside of the front panel.
The F1 error code indicates that the signal from the water level pressure switch on the machine control board is out of the normal range. This can be caused by the pressure hose between the bottom of the tub and the pressure switch being pinched, twisted or kinked. If this pressure hose is okay, then the machine control board will need to be replaced to correct this problem.
The F1 error code on this washer indicates a Primary Control Board failure. It is likely that the machine control board will need to be replaced to correct this problem.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem. A pinched or twisted air hose can cause this fault code. When you open the console, check the air hose connected to the pressure switch on the machine control board. If it is pinched or crimped, Its recommended to rerouting the hose to resolve this problem. This may fix your problem without replacing the control board. NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself. As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
please chek this link,which will be helpfull..
http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
Thanks for contacting Fixya.com
Kemmore elite oasis model # 110.28042701 type 581washing machine not turning on.
Make sure it is receiving power. Having confirmed this what works and what does not. Resubmit your inquiry with specifics so help can be rendered.
Nov 23, 2015 | Kenmore Washing Machines
There is grease coming from uner the washing machine and it makes a loud noise when it is spinning? Sometimes the washing machine will get hung up on the spin cycle?
Oil usually from the leaking transmission. a clutch not engaging might make a noise but u will get no real spin and clothes remain wet? if it was bad motor coupler if u have direct drive u would also have no spin or wash cycle. I suspect a bearing prob withing the tranny SORRYYYYYYYY :(
Oct 17, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
I have a kenmore elite total care flex king size capacity plus quiet pak2 oasis that makes loud noises like a airplane when its in the spin cycle Model #110.28032701 which parts should be change?
If the washer is roaring during spin, the bearings are bad and you will need to replace the outer tub assembly.
Here is the part to order.
The part comes with a 365 day, any part, any reason return.
Nov 03, 2012 | Kenmore Washing Machines
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Elite Oasis HE washer model #27092600. It is making a loud noise before and during most of the spin cycle when it is trying to drain. What would cause this. I have had this machine since...
Mine was making a high pitch sound, thought a rock got under drum.... now it stopped yesterday full of water ... and won't spin or drain. What can I do here at home to fix it?
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Nov 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
32 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
