Question about Jabra BT125 Headset
Changed Phones. Need to connect Jabra BT125 to Katalyst, HELP
  • 557 Answers
Let fhone searts for bluethooth device and select the device then you can give connection code 0000 and connection wil be working
Posted on Oct 07, 2009
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
I change my handset now jabra bt125 is not
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Password is 0000.
Jul 03, 2009 | Jabra BT125 Headset
Jabra bt125 broken ear hook
It's kinda cheesy, but a piece of #10 wire fits perfectly into the hole. That's what I'm using now. Neither the original is very comfortable, but they work.
Jan 27, 2009 | Jabra BT125 Headset
Jabra bt125 won't pair to motorola razor v3
I had the same problem and found the user: Splut wrote in another problem the following solution: If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. I tried that to connect my Blackberry phone to my Jabra BT2010 headset and it worked!! I had tried everything prior without success. I hope this works for you. DIVA08
Dec 15, 2008 | Jabra BT125 Headset
Sigamtel S4 and Jabra BT125
SET YOUR BT125 JABRA  in pairing mode then try to seek in mobile
or reset your mobile
Sep 16, 2008 | Handmark Software MobileLists (950142) for...
I need to reprogram my Jabra BT125 to a new phone, but don't have the instuctions to do that.
7. Pair it with your phone
Before you use your Jabra BT125, you need to pair it with your mobile
phone. (Follow step 1-4 in fig. 3).
Jul 12, 2008 | Cell Phones
Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Feb 21, 2008 | Jabra BT125 Headset
Jabra BT125 Headset Logo
65 people viewed this question
Top Jabra Radio Communications Experts
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
