Question about Black & Decker Black and Decker CBG5 SmartGrind Blade Coffee Grinder - White
Source for replacement blade for CBG5 B&D Coffee Grinder
Is there any place where a replacement blade for Black & Decker CGB5 coffee grinder can be obtained?
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Posted on Oct 08, 2009
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
The tip on one side of the grinder blade has broken off...the machine runs well and has not had a lot of use. Can the blade be replaced; if so, how, and how much? SmartGrind CBG5.
I have two different coffee grinders and if it is just the tip of one side of the blades you can continue using it, if there is a large portion that is broken I'm not sure of that model. Hint: check to see if the part is still in the grinder set the grinder for the most coarse grind, don't turn it on, shake it upside down to see if the broken potion is still in the grinder. If you find nothing use the grinder unless the performance is less than you like.
Feb 10, 2011 | Black & Decker Black and Decker CBG5...
Cannot replace the grinder knob after cleaning. Will not turn and lock
sad have the same problem and no one seems to be able to answe . or shoud I say "willing to answer"
Dec 30, 2010 | Black & Decker Black Decker CBM210...
I just want to know how to clean it after use - it is a coffee grinder, SmartGrind
How to Clean SmartGrind Blade Coffee Grinder - White
1. Always unplug the unit before cleaning. Wash the lid in warm, soapy water - not in a dishwasher.
Wipe the grinding bowl, base, and other parts with a slightly damp cloth or sponge. Take special care
around the blades; they are sharp! Dry parts thoroughly. Do not immerse grinding bowl, base or plug
in liquid or under running water.
2. Never use harsh detergents or abrasive cleansers or scouring pads to clean any
part.
3. To remove residue or aromas left behind by nuts, grind one tablespoon of baking
soda in the bowl then wipe thoroughly.
4. Use the built-in cord wrap on the underside of the unit to store the cord
Nov 04, 2010 | Black & Decker Black and Decker CBG5...
I have Black & Decker Grinder Model CBM2 disrupted and wanted to fix it I could not open it. Opened the two screws and then opened the other three after the chair. But the lower lid was not opened....
  • after opennig 2 and 3 screws you should hold the shaft of motor with a screw driver from the hole on the lower cover and then turn the blade with suitable tool for opening the blade. after easily separate the lower cover from the body
Oct 18, 2010 | Black & Decker Black&Decker Coffee Grinder...
Nothing happens when I press the grind button
There's usually some sort of "tongue" on the cover of a coffee grinder that activates a safety switch when the cover is completely in place. Be sure the cover IS completely in place ,and be sure that the little tongue hasn't broken off . . . I have a simple grinder that needs the lid on, because it pushes a little rod down into a hole and activates the grinder. It's designed so that you can't actually activate the blade without the cover in place; of course, a paperclip *could* activate it, but that wouldn't be very safe, now would it?
Feb 10, 2009 | Black & Decker Coffee Makers & Espresso...
Cuisinart DCC490SA 10-Cup Coffee Maker
Does the black plastic thing not lift out of the coffee maker? I just scrub the black bottom and clear top in the sink or run it in the dishwasher. HTH-
Jan 28, 2008 | Cuisinart DCC490SA Coffee Maker
CBM205S - Black & Decker Coffee Grinder
make sure the top cover is depresed fully. There's a safety switch underneath it.
Oct 28, 2007 | Black & Decker (CBM205S) Electric Grinder
Black & Decker Black and Decker CBG5 SmartGrind Blade Coffee Grinder - White Logo
316 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Lyle Siemens
Lyle Siemens
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
