Question about Air Tools & Compressors
My kids tied the dog to my Sears Air Compressor--he tipped it over and broke off the nipple inside the tank. A screw extractor with liquid wrench and a 2500 degree torch will not remove the nipple! Any thoughts would be appreciated.
    Top Expert:
  • 12,866 Answers
U have torch if brass nipple braze a piece of pipe or bolt if u can fit one into middle of nipple and use either breaker bar or wrench for leverage if nipple other than brass tack weld into nipple
Posted on Oct 07, 2009
Testimonial: "Thanks--very helpful--glad I tried this site!"
How to change motor part That is striped
Stripped? You can drill into the bolt or screw and then screw in a screw extractor (a left-handed screw). Sometimes, just drilling straight through the bolt relieves tension on the bolt and it is easier to turn.
Make sure to use the right sized drill bit if you go the screw extractor route. Extractors are available from auto parts stores.
spray at some liquid wrench on the bolts to remove corrosion that may have caused it to freeze (seize).
Aug 23, 2014 | Cars & Trucks
How do you remove a broken spark plug
The problem is the porcelain. You really don't want broken bits and pieces dancing around your pistons. However you do need to push it down a bit so you can get purchase with your left- threaded screw extractor. You can also buy a special tool for this job.
However there is another possible solution:
From http://gmtnation.com/f25/spark-plug-broke-help-3081/
"After hours of thinking, tinkering and a few trips to the tool store I came up with a successful solution. I cleaned out the debris as best I could and made sure there were no obstructions above the porcelain center. Then I slowly turned the engine over until the cylinder's compression shot the core out. It came out with such force that it actually made a mark on the ceiling of my garage. After that is was pretty simple, used a #5 extractor (aka easy-out) to back the metal portion of the plug out. Upon further investigation it became evident that plug has either been broke for a very long time or was defective when installed at the factory. Most of the surface was corroded indicating it had been exposed for some time, very little of it appeared to be a fresh break."
Jan 18, 2014 | Vehicle Parts & Accessories
I am trying to replace the dip tube in my RheemPowerVent water heater but I can't for the life of me figure out how to get the old one out. The treaded metal cold water nipple is screwed into a circular...
1) Rheem power vent series:
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
2) Looking at product over-view manual: It says 'inlet connects directly to a dip tube which directs water to bottom of the tank.'
So it appears that dip tub is connected to heat trap nipple on cold water side
3) Sample manual for Rheem shows exploded parts list
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
The exploded view shows cold water nipple separate from dip tube, and shows dip tube gasket, and makes it unclear
4) Manual shows Rheem phone number:
1-800-432-8373
5) You can also post specific questions like this on pro water heater forum: http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project. As general rule, expert will not answer unless they know specific answer, to avoid dissatisfied customer.
Fixya is always less expensive than a service call.
Feb 05, 2011 | Rheem Flared Water Heater Dip Tube
I Have a Stanley air compressor Bostitch model APC-OL6-UK it is spitting brown liquid how do I clean this please
The brown liquid you are getting out of the compressor is water with rust in it from the inside the air tank. Somewhere on the bottom of your air tank there is a valve you need to open from time to time to drain the water from your tank. If you are getting rusty water from the air outlets you probably have a lot of water in the tank. If you can take the compressor outside, with pressure in the tank, where the water won't stain anything and slowly open the valve to drain the tank.
Feb 02, 2011 | Stanley Air Tools & Compressors
Galvanized nipple broke off in fitting
Hi grumpy, W/D here.
The easiest way to get a broken nipple out is to use a nipple extractor. It works like a bolt extractor, but has lobes that extend when you turn the end. I bought a set at a piping supply house for ~$10. This has 3/8", 1/2" and 3/4" extractors in it. If you do more than just a little pipe work, they're worth buying. I don't know the cost for a single extractor but they should be available too. Call ahead!
Best regards, --W/D--
Jan 14, 2011 | RTO Southland Pipe Nipple 10201 Galvanized...
Gas line cracked and nipple fell back into tank ..how do I remove gas tank to replace gas line and nipple????..ryobi 725r trimmer
Empty the tank by dumping into a can or something. Shake the trimmer around until the "nipple" falls out. Get a replacement fuel line and follow their instructions. When yoou put the tube back into the tank, have something that you can guide the line through the hole with. I used a small hex wrench. If you cut the tip of the tube at a sharp taper, it will be much easier to start through the hole. You might think of replacing the return line as well. You should not have to remove the tank if you expose the carb and remove the air filter...Good luck...Lee
Aug 02, 2009 | Ryobi Garden
Removing Chewed screw from Freelander Brake disc
Just a tip, you can avoid this problem in future, by using an impact driver, not expensive, and sold at most automotive stores, halfords, roadrunner etc. It impacts the stud, and twists at the same time, avoiding shredding the surface. It may still work on your stripped screw, if there is still some grip. It's a common problem on both the discs, and rear hubs on freelanders.
Jul 01, 2009 | 2003 Land Rover Freelander
Extracting a screw that broke 2 extractors
Drill as large a hole as you can down the centre of the broken screw, and use an "Easy-out" left thread screw extractor of as large asize as you can. If the rotor is out of the car, soak it in a mixture of Coke and light machine oil before trying to extract screw.
Jun 14, 2009 | Dmm Screw Extractor, #4
Drain valve on air compressor won't open or close
I would use an ajustable wrenck to try and open the valve. Being at the bottom and in the water, this is a common occurrence. to replace the valve, there is a Hex nut outer fitting (part of the valve) that you have to remove right by the valve "T" handle. Put a wrench on this and remove the complete valve. It too will be very hard to remove. When you install the new valve, use some anti-seize compound to make future removal easier.
May 31, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Singer sewing machine
First try leaving a few drops of penetrant (PB Blaster or WD-40)on each screw letting it soak in overnight. Then using as short of a screwdriver ,with the best fit to the screw, as you can fit under there put it in the screw head, push down hard and turn the screwdriver with a pliers. This should break them loose.
Jul 23, 2008 | Sewing Machines
Air Tools & Compressors Logo
129 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
