Question about Mackie 1604 Vlz3 16 Channel Mixer
Odd channels go out 1,3,5.....
I have a Mackie 1604 VLZ Pro that every now and then the channels 1,3,5,7 will just go out. When I take of the back panel, I can unplug and reseat all the ribbons and the unit will work fine again for a while. I confirmed with Mackie I had the right rev cable. Could this be an oxidation problem?
  • Mackie Master
  • 5,603 Answers
Unless you are in super humid environment, this is more likely a crack in the circuit board OR a bad connector on a ribbon cable. Also BROKEN or cold solder joint for a connector pin through the circuit board.
Good way to cause this with ribbon cables is to NOT distribute the load when pulling them off. Often the wires near the edge are stretched and make poor contact with the little forks that pierce the insulation.
CRC226 is a good product to use for contacts. Available at Home Depot in the electrical department. Blue spray can. Use sparingly.
Posted on Oct 08, 2009
Where I find power transformer of mackie 1604
You should be able to get this directly from Mackie service. Please see the link below for the contact information. Please note that the exact model number adn serial number will be required to insure that the correct transformer is obtained. There are a few variants of the 1604,
Dan
Link: http://www.mackie.com/support/service/index.html
Jul 19, 2011 | Mackie 1604 VLZ 3 16 channel Analog Mixer
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Some of my channels have stopped working 4-5-6-13-14-15-16 mackie 1604 vlz pro
If you havent ground looped the chanels. Most of the time the chanels need to be cleaned.
Dec 01, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
How can I hook up my ipod to the Mackie 1604-VLZ PRO? I'm not sure which control buttons, knobs or slides to use to to make it play. I plugged it into the "tape in (RCA)" jacks. I need help with the...
Easiest is to use a 1/8 inch stereo to 1/4 inch splitter cable (1/4 mono's) and plug into the tape input. Then use the tape level knob.
IF you want to use sliders, then plug the spliter 1/4 inch plugs into two channels and set the PAN controls for these to opposite ends and then you have to adjust two sliders to control the gain.
Sep 05, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hello. I'm missing the bottm plate of the mackie 1604 vlz pro. I bought it on ebay and the bottom plate that covers the internal parts did not come with it. Is there anything I can do about this? Do they...
Mackie does sell parts. If you cannot afford or get the part, procure some metal and make your own. Mackie is headquartered in Woodinville WA I believe.
(800) 898-3211 Monday-Friday, 8am-4pm Pacific Standard Time
Aug 06, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hi, Model: Mackie 1604 VLZ PRO When using the control room monitoring, even if the corresponding "SOURCE" switch of the subgroup/main mix is disengaged, there is still small volume of sound. This is...
You may be getting a small amount of cross-talk. How high are the gain settings and sliders when this occurs? Also, can you describe the overall setup that you are using? I'll check the prints, but you should not be getting any volume unless the gains are maxed.
Dan
Oct 15, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Ch. 10 does not work - Mackie 1604-VLZ PRO
Yes, the ribbon cable is the 1st thing I would check. You can check the ribbon like this: Disconnect said cable from the channels. Connect cable connector from a known good channel to the problem channel. If channel sounds the same trace a signal through the channel op-amps.
May 26, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 Vlz3 16 Channel Mixer Logo
272 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
