Question about Garden
I have a 6hp Honda pressure washer the only way it will start is if I spray with starting fluid then it stalls
stug_57u
  • 99 Answers
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Posted on Nov 01, 2008
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
SOURCE: pressure washer - can't figure out soap
Use your mouth to get the siphon started. That's what I did and mine worked great!
Posted on May 23, 2009
bozcro
  • 867 Answers
SOURCE: my gc160 pressure washer will start with a 'gunk'
it is not getting fuel.check if carb is getting fuel from tank, by removing hose at carb. make sure airfilter is clean ascarb cannot vacuuum in fuel if its dirty, try staritng without filter on.if all that is good, you will need to remove bowl from carb, may be dirty
Posted on Aug 09, 2009
  • 151 Answers
SOURCE: Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Posted on Dec 24, 2009
Generac 6hp pressure washer starts and runs fine, no real leaks, but it never builds up pressure.
after making the water connections, be sure to hold the trigger open on the wand for a couple of minutes before starting. All the air must be removed from the system before it can create pressure.
Aug 28, 2013 | Briggs & Stratton Pressure Washer...
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Sep 16, 2009 | Boating
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Apr 12, 2009 | Honda 8 HP Engine
Garden Logo
231 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
