Question about Dryers
One of the 3 "ribs" inside the dryer drum fell off. How does one go about getting to the outside of the drum to reattach the rib with its screws.
    Top Expert:
  • Dryers Master
  • 12,650 Answers
Disconnect power and remove rear cover to get to drum turn by hand till holes 4 rib are on bottom drop in rib and tighten screws
Posted on Oct 07, 2009
  • 867 Answers
Older models you take screws off around the top, check for them by lint filter too. then you pry the front(spring clips) and swing it open, back usually has a cheap hinge mechanism.
Loose rib in barrel of Maytag dryer How to fasten it back?
These ribs are made of heavy plastic and are screwed on from the outer portion of the drum. Remove the top and the front of the dryer to gain access to this ribs bolts and tighten
Mar 13, 2010 | Dryers
Tip
Hotpoint Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For Hotpoint Dryers
1970- 1990 standard capacity
Style: Flat with ribs
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
1b9906a.gifStyle: Flat with ribs
on Mar 06, 2010 | Dryers
Tip
Fridgidaire and GE Dryer Belt Replacement
Here are the belt diagrams for replacing your dryer belt for Fridigaire and Ge Dryers
For Fridigaire dryers 1970-1985
9b6122a.gif Style: Flat with ribs
Installation Tips: Ribs face toward drum
For 1985-1995
For 1995- present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
For Ge Dryers
1990 – to present
on Mar 02, 2010 | Dryers
How to install a multi rib dryer belt on my
remove the back!! top lid take 2 bolts out of the inside top of the front panel and two screws on the lower outside front panel remove the belt if its still on the drum ! slide drum outwards about 6 inches then from the back of unit slide the belt around the motor shaft and then the drum and hook around the idler tensioner slide drum back and reassemble
Jan 17, 2010 | Whirlpool LER4634J Electric Dryer
Tip
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
For Amana all models will look like this
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
How do you replace a belt on model 11060622990
Unplug the dryer.
Remove the lint filter.
Remove the 2 screws at the lint filter opening.
Use a putty knife between the top lid and the front panel to release the clips.
They are about 2 inches in from right and left sides where the top meets the front panel.
Lift the lid towards the rear of the dryer.
Look inside the top right and left corners of the front panel and remove the screws holding the front to the cabinet. Remove the door switch wires and set the door aside.
Place the new belt over the drum,ribbed side towards the drum.
Look under the drum for the belt tensioner. It is S shaped with a wheel on it.
Place the base of the tensioner in the slots below the motor pulley.
Feed the right side of the belt through the opening under the wheel with the smooth side of the belt touching the wheel.
Place this side of the belt over the motor pulley with the ribbed side touching the pulley.
Replace the front panel.
Hook up the door switch wires.
Replace the panel screws.
Reattach the top lid and lint filter screws. Replace the lint filter.
Plug in the dryer.
Jan 03, 2010 | Kenmore Dryers
How do I change the drive belt?
Unplug the dryer.
Plug in the dryer.
Do you have a digram to show you how to change belt on inglis dry
amana.gif Diagram A
transparent1.gif frank.gif Diagram B
transparent1.gif frig.gif Diagram C
transparent1.gif ge.gif Diagram D
transparent1.gif maytag.gif Diagram E
Installation Tips: Flat side of belt against drum
transparent1.gif admiral.gif Diagram F
transparent1.gif westing.gif Diagram G
Style: Flat belt
transparent1.gif whirlpool.gif Diagram H
belt1.gif Diagram J
belt2.gif Diagram K
belt3.gif Diagram L
belt4.gif Diagram M
Jun 25, 2009 | Whirlpool Inglis IP8200 Dryer
The belt has come off the dryer drum. I dont know how the tensioner goes back on
stick the belt pulley in the holes closest to the motor. if you have a belt pulley like this. get the belt and hold it together so you have a loop at the end and run under the pulley so the pulley lifts up and put the belt on the motor shaft. the belt always goes under the pulley so you are lifting upwards
Jun 21, 2009 | Dryers
Dryers Logo
Top Dryers Experts
