Question about MidiLand MLi 460 Computer Speakers
Midiland surround sound
I found a surround sound system in my late brothers house that I believe has never been hooked up. It is an older system and is Midiland or midland system model # mli-467a. There is no manual or any instructions on how to hook up or use. Where can I find some help installing it or finding out some info on it. Thanks.
SOURCE: MIDILAND MLI-818 SUPER 3D AND CAPPRICIO SYTEM SPEAKERS
Unstick your capslock key if you want someone to actually read your post...
Posted on Aug 30, 2008
torresfvr
  • 69 Answers
SOURCE: I recently got a new computer & it has windows
a bit odd that.. sound like 2.1 to be.. try the 2 speaker setting.. which i think you have..
so i assume if you did not plug L and R into the sub,
But you plugged sub into the PC and before you had sound but after vostro you have none?
sound like a possible fault on the sub?
have you tried this elsewhere?
Posted on Jul 25, 2009
drifterK
  • 4924 Answers
SOURCE: how do I get driver
If they plug into the green outlet in the back on the sound card ..they do not need driver ..cause it is a plug and play device ..
if you do not have sound ..either you did not plug them into the right out-let (plug into the green in the middle ..or if it is a sound card with more than 3 plugs ..look for teh simbol for speaker out ..(SPKout )
be sure they are powered..and the volume razed..
If you have sound problems ..check on the speaker volume icon into the task bar ..by click once ..and in there look not to be ticked the mute case..
In final reinstall the sound driver ..If it is an on board card ..than it will be on the motherboard drivers cd ..just insert it and choose the audio driver and run it ..
Posted on Sep 04, 2010
SOURCE: Problem with Midiland S2 4030 powered speakers
Mike, I have the exact same issue. Did you have any luck resolving this?
Thanks,
Jim
Posted on Oct 09, 2010
billfox1966
  • 231 Answers
SOURCE: Hey I lost the remote
you can try programable remnotes using the hometheater code entries , but more than likely you will need to buy a factory replacement remote.
http://www.remotecontrolscenter.com/
Posted on Nov 29, 2010
Testimonial: "Thankyou "
Santo dp32649 want to hook up surround sound but sound won't come thru speakers in TV mode
If you expect the sound to come back through the HDMI connection when watching the TV as the source, e.g. using an antenna, then both the TV and the surround sound processor need to support Audio Return Channel (ARC), a feature new to HDMI 1.4. Further, most TV's even if HDMI 1.4 compliant support it on only one of the inputs - check the setup guide. To accomplish the same thing with older equipment, simply run a separate audio connection from the TV back to the surround sound processor.
Aug 06, 2014 | Audio Players & Recorders
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
How can i get my surround sound working for my ps3 i have a philips hts3357 home cinema please help
Hook the ps3 into the tv. Hook the T.V out going to the surround sound system and you should get your game sounds out of your surround sound.
Mar 01, 2011 | Philips HTS3357/05 Theater System
Thanks,
Jim
Jan 11, 2010 | MidiLand S2 4030 Computer Speakers
I hooked up a samsung surround sound but i cannot get to the menu of my surround sound system, i go to the av input and then menu shows up for 2 seconds and then dissappears and says no signal please help
I think we need to know more specific info about both the samsung and your TV/monitor. Could be either. If the TV is saying no signal, believe it. Check the connection, try another cable, etc.
Nov 28, 2009 | Audio Players & Recorders
I have an LG LCD TV (LG 37LG5000 37IN). I also have an older DVD Home Theatre System (SONY DAV-DZ100). It seems that the surround system works well with DVDs but I cannot get the sound to work with DIGITAL...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Oct 04, 2008 | Televison & Video
Vizio Sound Problem
I've seen the same problem, went thought a couple of cable boxes. Turned out to be an AC line problem. Try plugging the TV into a different out, maybe in another part of the house.
Jul 16, 2008 | Vizio P4221 Television
Hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Feb 17, 2008 | Vizio VX32L Television
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Display shows "L" and "R" highlighted in Red
maybe the sound setting is in mono mode versus stereo surround,this only occuring on older model surround systems.   if that doesnt do it , try unhooking  and then hooking the speakers back up  or ; maybe they are even...................switched      hope i could help            i  man   fixxxxxxxxxxx
Aug 27, 2007 | Panasonic SC-HT730 System
MidiLand MLi 460 Computer Speakers Logo
179 people viewed this question
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
