Question about John Deere Garden
317 John Deere Tractor. Engine sounds like it is retarded on timing. How do check and or adjust timing
  • 472 Answers
CK THE FLY WHELL KEY
Posted on Oct 13, 2009
If brakes are not locked together on steep ground the John Deere tractor will kick out of 4wheel drive and run away.
Operating - Operator's Manual - John Deere
manuals.deere.com/cceomview/...A9/Output/OMM139226_A95.html
Slow down before you make a sharp turn or operate on a slope. ... Before starting engine to drive tractor, adjust operator seat to desirable position. ..... If lock does notdisengage, depress one turn brake pedal, and then the other. ... The 2-wheel drive (2WD) / 4-wheel drive lever (A) enables the tractor to be operated in two or ...
A Guide To Safe Farm Tractor Operation - National Ag ...
Nov 23, 2015 | John Deere Garden
My brakes are sticking and/or locking up on my john deere 2355 tractor has anyone had this problem and fixed it
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/...J7/Output/OMLVU17926_J716.html
See your John Deere Dealer. Fuel pump not ... Brakes dragging. Misadjusted .... Parkbrake locked. ... Cruise Set/Decel switch is held or stuck on. No cruise ...
Service Engine - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM139226.../OMM139226_A99.html
Warranty repairs must be performed by an authorized John Deere dealer. ... 3. Push down on front of hood to lock latch. ... brake. 2. Stop engine. Allow engine to cool. 3. Raise hood and latch open. 4. ... Remove right side engine shield from tractor. ....Check engine speeds when engine is warmed up and not under load.
Oct 29, 2015 | John Deere Garden
Replace a fanbelt on john deere 4020 diesel tractor
Most older models had the adjustment on the alternator. loosen it and push it toward the engine. remove & replace the belt. Pull the alternator away from the engine until the pulley cannot be turned by hand due to the tension. Tighten the adjustment bolt to secure it. Don't overtighten the belt.
Sep 22, 2014 | John Deere 4020 Gas & Diesel Tractor...
Starts good runs good on idol, but under load misses
Is it a lp,gas are diesel?...If lp are gas check timing and point are in some cases the flapper in the carberator.If Diesel it possible the flex ring is coming apart in the injection pump and stoping up the return lines at the injectors retarding the timing advance in the injector pump..very common in the 3020 4010 4020 4320 and 5020 John Deere ag tractors...
May 16, 2010 | John Deere 3010,3020 Tractor Basic...
Engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a John Deere 317 tractor that does not start. The engine turns but does not fire. The plugs and points are good. I do not get a spark at the points or plug. What should I check next next.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Nov 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317.  They were made from 1979 to 1982.
You can only get manuals either through here:  http://techpubs.deere.com/deere/Default.aspx  or from a dealer.  They're expensive.  You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
Oct 07, 2009 | Garden
1981 John Deere 317 carburetor screws for the idle, and choke are not set correctly. Will not start.
When it comes to carb adjustmant,my recomandation is for you to seek a professional to do it for you. You can fight with it for a while and not get it,small engine mechanics that do it all the time could have your problem fixed rather quickly and wouldnt charge you much,but thats up to you.
Aug 02, 2009 | John Deere 3010,3020 Tractor Basic...
Garden Logo
345 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
