Question about Acer Aspire 5050-3242 Notebook
My wife's laptop fell and now the registry is corrupt. I downloaded and burned a repair vista disk and tried everything on there with no results. Registry Corrupt. Is it possible a wire or something got knocked loose? Is the registry in the mother board or the hard drive? I don't see how files can become corrupt from a fall.
  • 448 Answers
The registry is THE program that tells your computer, essentially, how to run--what steps to take to load the various setup aspects etc. that have been compiled for your computer. It is not hardware, it is part of software. If you have a restore function, and you can get to it (maybe through going to safe mode--check your manual for how to get to that). you might be able to get things back, but you may have to wind up reformatting the hard disk, which means you lose everything on the computer. Actually, there are two copies of the registry. In case one gets corrupted, the machine will try to boot the other one, so if your machine is, with several reboot tries, not able to get the registry, then you have a significant software problem.
Posted on Oct 07, 2009
  • 26 Answers
Maby but it might be just bad harddrives are just a metal disk could be scrathed were the head slid acrost it but open up the plate and see if the harddrive is lose its under 1 of the plates on the back..
Having with my dell inspiron window 7 laptop(hard drive/corrupt registry) how do I restore it too factory setting?
If you have tried every system restore point, that is when you open system restore you checked show more points, and have tried all of them, then you must reinstall the OS.
If you don't have a windows disk, you can download win 7, it is legal to download and use for 30 day's, but then you are suppose to register it.
If you download it, you should check the hash number, but it's not a second deal, you would need to read about how to do this.
I will post a link for win 7 downloads, for the most part I can say these are not touched, they are ok.
These are ISO files, so you need a software like free ISO burner, this will open and burn the file to a DVD disk, now you have a win 7 install disk.
You can also use the win 7 disk to repair windows, so if you do burn it, try repairing windows with it first.
Here is a link if you need to see how to install win 7, with pictures.
http://www.buildeasypc.com/sw/windows_7/install_windows_7.htm
Here is where you can get win 7, pick the version you have now because the serial key only works for that version you have now.
http://malwaretips.com/blogs/download-windows-7-sp1-iso/
Apr 12, 2013 | Dell Inspiron Computers & Internet
My VAIO laptop freezes after a few minutes and I have to remove the battery and reboot. Help! Thanks
This seems to be a common problem with laptops over a couple of years old. Dust gets trapped in the copper fins and the fan of the CPU heatsink and reduces the efficiency of the cooling, which results in regular power off's by the laptop as it gets over it's upper temperature setting. The fix is relatively easy, just remove the heatsink unit, blow it clean with compressed air, clean the old CPU heatsink paste off with isopropyl alcohol (IPA) and spray a thin film of heatsink paste on the CPU.
Jul 07, 2011 | Sony VAIO Notebook
My system is verry slowe working
It could be many reasons:
Your laptop/desktop doesn't have much memory or diskpace available
Your laptop/desktop may have spyware, malware, or viruses
Your laptop/desktop may have antivirus software scanning in progress
Your Internet connection is slow
Your laptop/desktop may have device driver issue.
May 13, 2011 | Computers & Internet
My pc is very slow
-Can you provide more information about your issue?
-Are you using Windows XP or Windows Vista or Windows Seven?
When you say slow, is it slow when you are on the internet or slow when accessing or the computer or generally slow like everything is running slow?
Mar 25, 2011 | Computers & Internet
Can not get skype to work properly. Says computer too running slow
Corrupted Registry
System registry corruption leads to runtime errors and your computer slows.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer crashes due to problems with the computer memory. A faulty RAMmay result in Blue Screen of Death (BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer slows because of apreviously failed or incomplete installation. An incomplete or failedinstallation creates junk registry entries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer slows if the operating system has no adequate free disk space toperform its operations. Temporary files, temporary internet files, log files,browser cache and other files may occupy a large amount of your disk space andthus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen.
Feb 21, 2011 | ASUS Eee PC 1000HE Netbook
Pc slow
Learn why is a pc running slow and how you can fix the issues from: http://www.whyismypcsoslow.net/
Feb 11, 2011 | Acer Aspire One PC Notebook
Computer turns on, however after 2 minutes
Corrupted Registry
System registry corruption leads to runtime errors and your computer crashes.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
Faulty RAM
Your computer freezes due to problemswith the computer memory. A faulty RAM may result in Blue Screen of Death(BSOD).
Your computer freezes because of a previously failed or incompleteinstallation. An incomplete or failed installation creates junk registryentries and thereby system crashing problem.
Your computer freezes if the operating system has no adequate free disk spaceto perform its operations. Temporary files, temporary internet files, logfiles, browser cache and other files may occupy a large amount of your diskspace and thus generating runtime errors that crashes your system.
May 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Sony VISTA...operating system can't be found
download from the internet..
http://isohunt.com/torrents/?ihq=vista
you need to instal first the Utorrent downloader..
Sep 11, 2009 | Sony VAIO VGN-FZ240E/B Laptop
Two different error messages
Try this first (I know your drive is "inaccessible"): Hopefully you have a Vista installation disk, if not download and burn this iso file with Img Burn or similar program:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
Insert the disk in your drive even if you have to insert a paper clip into the little hole on the drive faceplate to open the drive bay door.
Try to boot into the Vista installation window. If you can do that, run the start up repair utility.
Please do not rate this post(s) until we have tried more solutions, as there are some other remedies, but try this one first.
If this doesn't work for you, please post back.
Jan 30, 2009 | Microsoft Windows Vista Home Premium with...
Acer Aspire 5050-3242 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
