Question about Psi Blue Max 2200 High Pressure Gas Power Washer
The spray gun doesn't stop spraying...
When using the Blue Max sprayer, the sprayer has water going through it without me pressing the spray handle. I have the engine running, water turned on and before I squeez the trigger, the water is already coming out full force. What is the problem?
2 Suggested Answers
  • 5546 Answers
SOURCE: I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Posted on Jul 04, 2009
My Ortho spray gun is not functioning.
Is it a hose end sprayer? Probably something blocking the pickup tube. Wash it out well with water. Wear a faceshield and use compressed air to blow opposite normal flow. To prevent this fill the sprayer through a fine mesh filter.
Jun 04, 2014 | Air Tools & Compressors
440i wont stop spraying
Either your gun is dirty and the valve spring can't close the tip valve properly or the seat it pushes against is damaged. First try cleaning the gun very throughly. Take it apart and get everything out of the gun that doesn't belong there. If it still does the same thing you can buy a repair kits for the paint guns but they're usually expensive and you're almost always better off replacing the gun.
Sep 29, 2012 | Titan 440I Spray Guns
Where to find parts of the paint zoom gun sprayer?
Hi, parts easily can be found on amazon, here Amazon com paint zoom gun sprayer parts take a look. Wish you best of luck. Dean
Jul 06, 2012 | Air Tools & Compressors
My graco xr5 sprays when i turn tip to spray position
If paint comes out of the spray gun after you release the handle, your problem is inside the gun. If the needle tip or seat are damaged or the spring that holds them closed is broken, paint will be able to get past the the needle and will come out of the gun even when the handle isn't held open. The stock spray gun that comes with the the XR5 doesn't have any servicable parts inside it so if it isn't working properly it may be garbage fodder. If you have an aftermarket gun, rebuild kits may be available.
Jun 13, 2012 | GRACO INC Magnum Xr5
Porter cable PSH 1 - clogs even with thinned paint compressor 4 gal 5.1 scfm
strain paint befor using. run water in gun or thinner to see if it will spray it before using and mix paint to the consistancy that spray gun or paint requires for spraying ( fine strainer)
Feb 04, 2011 | Porter Cable Gravity Feed Paint Sprayer
MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
May 22, 2010 | Campbell Hausfeld Air Comp Basic Spray Gun...
Bought anCampbell Hausfeld airless paint sprayer,
no fluid gets to nozzle or comes from nozzle.
sounds like your fluid line is pluged or the gun is pluged at or before the tip
Dec 28, 2009 | Air Tools & Compressors
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
105 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
