Question about Canon PIXMA MP600 all-In-One InkJet Printer
Paper feed problem
The paper doesn't feed right, with the auto feeder it pull the right side (facing printer) and gets stuck, from the cartridge it veers to the left side and damages the paper. I've tried everything.
  • 1 more comment
  • Anonymous Mar 20, 2014
    when ready to print out document,the feeder only takes the left had side but not the right through, hens the paper leans to the right and stops the feed
  • Anonymous Mar 22, 2014
    papers are stuck on the lower right side of the paper, or the lower right edge of the paper.
  • amor
    amor Apr 02, 2014
    same like mine
  • Canon Master
  • 1,113 Answers
Sound like something foreign is in paper path
Posted on Dec 24, 2007
Paper gets stuck pulls downone side only
Leading cause of paper jams and misfeeding is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Jan 29, 2012 | Lexmark X5650 All-in-One InkJet Printer
The paper will not feed properly into my mx320 canon printer. It pulls the paper in on the left side but not the right side. I can see no paper stuck anywhere on the rollers. I have removed and replaced...
The mX320 being a rear sheet feeder model can suffer the problem of something falling into the feeder and causing the paper to jam on entry.
To find what has fallen in your will need to gently pull back the fed paper and look at its leading edge. This will show a heavy "Nick" in the edge. observe where the nick is in relation to where the paper is fed and that will indicate where the obstruction is in the feeder. Use a bent paper clip (L shaped) and see if you can feel and dislodge the culprit. Remove the ink cartridges and turn the machine upside down and give it a good shake. hopefull the drawing pin/paper clip/notice board pin will fall out and the world will be at peace once more.
Good luck.
Aug 07, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Paper get stuck every time I try to print. I notice the paper just slides a bit inside and then on right side it just gets collected and I have to turn printer off to clear paper jam. please help. thanks.
Leading cause of paper jams is debris/foreign objects that have accidentally fallen into the paper feed area.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Apr 28, 2011 | Lexmark X6170 All-In-One InkJet Printer
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Blank lines and doesn't feed properly
Please clean the print nozzles :
  1. Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
  2. Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
  3. Continue doing this until it looks clean.
  4. Then dab the cartridge on the towel to make sure the ink is flowing.
  5. Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
  1. Paper jam:
If the paper is lodged too far into the printer and can't be removed:
  1. Press the power button to turn the printer off.
  2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
  3. Close the front cover.
  4. Press the power button to turn the printer back on.
  5. Resend your document to print.
Ensure that:
  • The paper is a recommended paper for inkjet printers.
  • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
  • The printer is on a flat, level surface.
  • The left paper guide is against the side of the paper.
  • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
  • The left paper guide does not cause the paper to bend in the sheet feeder.
  • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
  • Envelopes or the appropriate specialty papers are selected in the printer driver.
  • You are using a paper or envelope size supported by your printer.
May 10, 2008 | Dell 922 All-In-One InkJet Printer
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
257 people viewed this question
old marine
old marine
