Question about Moultrie MFH-DGS-100 Digital Camera
Nothing shows up in the window when you turn the unit on. I replaced the batteries and still nothing
National geographic weather trouble shooting
The order of replacing batteries is important. The outdoor unit batteries first, then the indoor. You wait 10 minutes until the outdoor unit starts sending data.
Jun 16, 2014 | Televison & Video
The laptop lenovo z560 does not switch on. With battery it shows 2 short flashes of battery charge idicator, an one long (about 10 sec) and than nothing is happening. Withou battery nothing happens after...
Hi smialkovskyi,
With this specific concern that you do have, unable to turn on your Lenovo Z560, there 3 components that need to be checked. Your battery, the AC adapter (charger) and as well as the DC In port.
1.Based on what you have said, with the battery alone you have noticed that it's led indicator will show however still can't turn on system. Battery seems to be in good condition however no enough charge to turn on the system.
2. For your AC adapter, when you're using it without the battery nothing happens. To check if this is defective try using another AC adapter that is compatible to your unit. If your computer turned on using another AC adapter then your charger needs replacement. (You may also try using your charger to other unit where it is compatible, just to test).
3. However, if after doing the previous instruction and still system won't turn on then it could be the DC In port which is defective. This port is built in to *********** board.
After doing all these you need to contact Lenovo. They might be replacing your charger or *********** board if system is under warranty.
Hope this helps.
Thank you for using Fixya.
Jan 28, 2011 | Lifetime Lenovo/IBM IdeaPad Z560...
Handset will not charge
firstly, try to use another charger, if the problem continue, you can replace the battery of the phone and if this still continue replace the charging port with a good one .
Jun 02, 2010 | Uniden DECT 6.0 Cordless Telephone...
Turn key and nothing happens, replaced the starter, now it is only clicking from the new starter. I have a new battery instaled that will show 12 volts on my dash when connected to another battery jumping...
if you replaced the starter with a remand unit it could still be a bad starter(personal experience),but if your battery show 12v only when being jumped your battery is having issues,take the battery and have it checked if it was replaced before the starter it could have problems due to the starter drawing to much at once and not recovering,and also have the alternator checked out this will kill a brand new battery very quickly even with nothing on.
Jan 03, 2010 | 1998 Cadillac Seville
A/c fan wont turn on after replaceing parts
This is showing a 98 caravan,is this a window unit?
Oct 06, 2009 | 1998 Dodge Caravan
The dispaly is blank...nothing shows up..
Did you try to depress the lamp button on the top left side of the unit to make sure that the lamp was turned on.
Also you may have a set of bad batteries .. replace them.
JG
Jul 09, 2009 | Magellan Triton 400 Handheld GPS Receiver
CP685AVR/BF685 Power Contro.
It is likely the battery. These batteries are designed to last 3-6 years in a UPS. The good news is that if it is the battery, it is completely user replaceable and you'll have a Cyber Power unit that works just like new with a new battery. What may have happened is that the battery was weak, and you may have had a slight dip in the AC power. This caused the Cyberpower unit to switch over to the weak battery which couldn't handle the load. The unit then turned off. When you press the "ON" button, the unit will go through a self-test that checks all of the components and the unit will not turn on and be functional unless all of the components come back with a PASS, including the battery. If possible, test the battery with a voltmeter, it should read around 13.5, but not lower than 11.5v DC. However, with the unit over 3 years old, it almost certainly the battery. Here's a link to a replacement battery for the CP685AVR: http://www.batteryinternational.com/cyber-power-cp685avr-ups-battery-ups-batteries-f1.html
Hope this helps.
Jun 28, 2009 | CyberPower (CP685AVR) UPS System
Window a/c unit won't turn on...dead.
Made an appt. with a repairman.
Jun 22, 2009 | Heating & Cooling
Lifedrive won't power on
When you plug the unit into the wall to charge, poke the reset hole in the back of it at the same time. This should reset the internal recharging mechanism in the Palm. Let it sit for a couple of hours and then see if it will come on.
Jan 03, 2008 | Palm LifeDrive Handheld
Creative Zen won't turn on
polish the battery contacts (including inside unit) with a pencil eraser.
Jun 09, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Moultrie MFH-DGS-100 Digital Camera Logo
14 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
