Question about Canon Office Equipment & Supplies
I have a problem with copier GP 225 it gives E003 how do I clear this code?
My Xerox machine show the error.
How can i solve the error code E003?
Posted on Feb 17, 2013
    Problem Solver:
  • 10 Answers
Fuser temp not rising at correct pace. could be thermistor,thermal switch or fuser lamp
Posted on Oct 07, 2009
  • crajasekar25
    crajasekar25 Feb 17, 2013
    pls tell me for solve the problem
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Title : E003-0000 is displayed upon recovery from sleep mode
Error :
Workaround :
When a machine is in sleep mode and is recovered an error code "E003-0000" was displayed.
It is caused during the fixing temperature control at recovery from sleep mode, electrical noise affected the thermistor.
In order to increase the length of time for idle rotation of the drum (by 30 sec) at start-up and prevent electrical noise from affecting the thermistor, make the following selection:
Service mode (Level 2)> COPIER> OPTION> BODY> DRM-IDL = change the setting to '3'
Note: The length of time for idle rotation is being increased by 30 sec.
This mode will delay start of the machine by 30 sec.
or
Product : imageRUNNER 7086 imageRUNNER 7095 imageRUNNER 7105
Title : E003
Error :
E003-0000 Error Code can be displayed when the reading of the main thermistor is below 70 deg. C for 2 sec. after it has exceeded 100 deg. C.
Workaround :
1. Although the fixing heater or the temperature-detecting thermistor may be faulty, before replacing these parts, check J508 on the DC controller PCB for poor contact and refit it if necessary.
2. Make the following selections to clear the error code: [Service mode > COPIER > Function > CLEAR > ERR > OK]
Jul 18, 2013 | Canon imageRUNNER 5000 Copier
How to remove error code (E000004-0010)from canon
Use this mode to clear an error code: E000, E001, E002, E003, E004,
E032, E717.
Using the Mode
1) Select <ERR> to highlight, and press the OK key.
2) Turn off and then on the main power switch.
Jan 05, 2013 | Canon imageRUNNER 5570 Copier
Canon Ir2318 error code 00003
the code is related to the fuser section.If the machine is new then enter the service mode by pressing additional function and then * and clear it in error clear , if it is old machine then check the fuser for open thermistor,broken element .
Aug 24, 2011 | Canon imageRUNNER 2200
Canon iR 2022 gives a system error E000 and error E003, what could be a problem?
how to clear error code e000 please help me copier ir 2022 show me how to clear
May 19, 2011 | Office Equipment & Supplies
Canon Image Class D860 - Error message E003. How do we correct?
Under service mode ( MENU and # ) find CLEAR, and select ERR ( if you cant find err, select ALL ), and OK.
Restart machine.
If that does not help change the whole fixing assy.
E003 means that you have temperature problems in fixing assy.
If clear does not help, that means that you have bad thermistor or fixing ceramics.
Jun 29, 2010 | Canon imageRUNNER 400S Copier
System Error E000 and E003
E002 Error code details Heater temperature error (fails to reachspecific level; inadequate increase)
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Action
 See the description for E003. E003 Error code details Heater temperature error (abnormal drop; low-temperature detection)
0000 The main thermistor reading is lower than 140°C when paper is moved.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Action
1. State
 Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate?
 NO: See "The fixing heater fails to operate."
2. Wiring
 Is the wiring from the DC controller PCB to the fixing film unit normal?
 NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
 Try replacing the fixing film unit. Is the problem corrected?
 YES: End.
 NO: Replace the DC controller PCB.
Jul 28, 2009 | Canon imageRUNNER 2000 Copier
Canon GP 225 - Error code: E007-01
This can be either of three main thing.
1. The machine detects the film out of place and needs to be reset, you do this by activating the service mode. Insert paper clip into hole (inside machine), then * * and service mode shud activate, then click error code and clear all errors.
2. The film is out of place, the fuser needs to be removed and the film manually moved back to the hope position
3. The film is torn and needs to be replaced (LONG WORK AHEAD)[/code]
Good Luck!!
Mar 18, 2009 | Canon Office Equipment & Supplies
Canon gp 200
what the canon gp 225 ip address?
Feb 18, 2008 | Office Equipment & Supplies
E003
problème d'installation d'une imprimante canon lbp 1000 laser son driver ne fonctinne pas
Feb 09, 2008 | Canon imageCLASS D860 All-In-One Laser...
182 people viewed this question
old marine
old marine
