Question about LG WM-2077C Front Load Washer
How dow I winterize LG front load washer?
We close up our cottage for the winter and there is no heat at all and we are in Canada where it gets pretty cold. Thank you!
    President:
  • 1,304 Answers
Very simple
get a towel
take off the back wall
remove one of the pump hoses
id remove the front one since the back has a check valve
let the machine
drain and you should be fine
you can eith recoonect then or when you get back
Posted on Oct 07, 2009
Can i leave my 19" LED TV in my Cottage in PEI. Over Winter if i wrap it in a blankket. Thankyou
Not a good idea unless packed very well in insulated box or container and if it is nineteen inch take it with you.
Mar 15, 2012 | Toshiba Televison & Video
LG WM2277H front load washer, how do I fully drain it so it can be stored in a Pod in the winter and moved to my new house?
It's a bit late, as I guess you have moved by now!
The best way to drain fully is to remove the outlet hose and let the machine lean backwards against an outside wall so that all water drains out.
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 11, 2011 | LG WM2277H Front Load Washer
MY FRIDGE CUTS OUT WHEN THE POWER FAILS EVEN IF THE POWER JUST FLICKS ON AND OFF WE CANNOT RESET IT HAS WE ARE ONLY AT THE COTTAGE WEEKENDS, SO WE LOSE EVERYTHING INSIDE
other than running your fridge on its own power source or fitting a gas operated fridge,(bottled gas) you must leave it empty,with the door open.....our friends in Canada have gas for heating and fridge /freezer and a generator, so they dont suffer any power cuts in winter.
Sep 09, 2010 | Samsung RB215LASH
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
I have a quietline washer/dryer how do I winterize it
there should be a panel on the front
open that you should have acess to the pump
open the pump and allow all water to drain
turn the water off at the isolators
winterized
hope this helps
Oct 28, 2009 | QuietLine WD-9900 Front Load Washer /...
How do we winterize our new LG front loader when we leave for the winter? Is it ok to put RV antifreeze into the tub?
Yes, my owners manual says to put one quart of RV Antifreeze in the drum of the tub then run the machine on rinse cycle. Next, shut off water supply and disconnect everything from washer and your done. You may want to get an owners manual online to confirm with your model! Mine is a Kenmore which I believe is same as Whirlpool!
Oct 05, 2009 | LG WM-2077C Front Load Washer
Proceedure to winterize washer
HI thanks for your question. the easiest way is to. pour plumbers anti freeze in it 1 gallon should do it . thanks the appliance doc. oh, start it up in the wash cycle for a few minutes, to cycle the water.
Oct 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
LG WM-2077C Front Load Washer Logo
1,296 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
