Question about Homelite Garden
Carburator will run motor but will not let it stay
Ryobi weed eater carburator will run motor but will not let it stay on. 3100cc motor.
  • 448 Answers
Most of us, at one time or another, leave fuel in trimmers or mowers for too long a time without running them. This causes the fuel to gum up and block passages, etc. A good idea is to add a fuel stabilizer (available at almost any hardware store) to the fuel or fuel/oil mix that you use for your small engines. It will allow the fuel to stay viable for a much longer period of time.
If you decide to actually diassemble your carb, and you have a digital camera, I would advise you to take picture along the way unless you are very good at remembering where things go after you have taken them apart. You also will probably find limiter caps over the setting needles. Sometimes you can simply pull them off; sometimes it is more involved than that. I would simply try spraying a carb cleaner into the carb (with the air filter removed), letting it sit for a few minutes, then try starting again.
Hope this also helps.
Posted on Oct 07, 2009
    Problem Solver:
  • 3 Answers
Take caburetor off, remove diaphram,turn adjustment needles to seat countig turns and remove, spray all ports liberaly with carburetor cleaner and blow out with air. reinsert adjustment needles to to the same turns from seated position. Replace diaphram with new. May require some tweeking of mixture after starting the motor.
Murray weed eater won't stay running
have to go further in the carb, If you left 'todays' ethanol gas in the weed eater for more then a few months, it probably messed up the Carb. Ethanol gas is very bad for carburators on any machine
Aug 31, 2015 | Garden
Weed-Eater
head is more than likely worn.try replacing
Jun 15, 2013 | Garden
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Need carbureator jet settings for snapper SKU 952711718 weed eater motor
screw all the way in and back out 3/4 of a turn. Then adjust the bottom screw out 1/4 turn at a time till it cranks and continue adjusting till it idles good.
Then adjust the top screw till it stays running when going to high speed abruptly.
Jul 22, 2011 | Garden
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Rhobi weed eater stalling
Try spraying some carb cleaner into the intake while its running - with the air filter out..
If that doesnt help & if it sat for a long time without being run - you might need to get the carb reuilt..
Hope this elps !!
rate me good ;o)
Jul 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Adjustment of the gas air mixture on a Ryobi ss30 weed eater
aside from carb adfustment. remove exhaust screen and scrape off carbon with piece of wood. also repplace the fuel pickup filter in the tank. couple buck at the home depot.
Jun 19, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
164 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
