Question about Panasonic KX-FL511 Plain Paper Laser Fax
Trying to fax it reads sending 1 it will not pulled paper through
  • 56 Answers
Try changing your separation pad . If your feed roller rotate clean them with alcohol.
good luck
Posted on Oct 22, 2009
Transmit Error
To eliminate a machine problem, make a copy of something; you are using the scanner to verify if the mechanics are OK.
To eliminate a phone line problem, take the fax to another house or office and try there it again.
Oct 30, 2009 | Panasonic KX-FPG391 Plain Paper Thermal...
Fax uf 590
Pull open the bottom of the operating panel just above the paper tray one inch 1". Clean the small scanner glass with alcohol, it's hard to see. It's just above the first rubber roller at the black base of the machine.
Feb 19, 2009 | Panasonic UF-590 Plain Paper Laser Fax
Not receiving faxes
Folio is not what you want. The usual is letter (LTR) or 8.5 x 11. You may have to check the settings to set the default paper size.
Jan 14, 2009 | Canon PC-1080F Plain Paper Laser Fax
Machine reads "document jammed"
its the problem of the rollers which pulls the papers they r worn out.I've seen this before repairing computers and asked about fax machines while I am there. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Sharp ux-b700
do you hear the tires trying to pull the paper? if yes clean with alcohol ( may be slipping)
Aug 12, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Intellifax 775
Lift up the document feeder (where the keypad is) and look for something blocking the paper path.
Jun 19, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Multiple page faxing
press fax then press faxtel nummer . put page 1 on the glass press start mono (b/w mono) You will be asked if there are another pages. Press 1  and put the next page onto the glass. When finished press 2 (No, no more pages). machine will start calling and sending.
BTW Did you read the handbook? This is explained within the handbook which can be downloded from the brother homepage of your country!
Oct 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Panasonic KX-FL511 Plain Paper Laser Fax Logo
79 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
