Question about GE Spacemaker JVM1640SJ Microwave Oven
Slight crack in oven door just below the handle. Should door be replaced?
  • GE Master
  • 9,047 Answers
It may be that the handle is getting loose, and cracked the outer door panel.
If so, the outer door panel and handle would need to be replaced.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Posted on Oct 11, 2009
Can a GE microwave door handle be replaced?
Is this an over-the-range microwave oven? If so, you can usually remove the door by first removing the grill vent above the door (by removing 2 or 3 screws first). With the grill vent removed, you can usually remove the door by opening it and lifting it up off its hinges. Place the door down on a blanket. Using a putty knife, you can pry out the black plastic RF shield (or door gasket). This is the most tricky part, and if you are not experienced, you may break that plastic since it is rather brittle. And if you do break it or crack it, then it must be replaced or the microwave oven will leak microwaves. But once you've got that removed, then you should be able to see and remove the screws that hold the handle to the door. After you replace the handle, it's a simple matter to push the door gasket back into place and re-install the door.
Sep 12, 2014 | GE Microwave Ovens
Ge spacemaker xl1800
A small crack is probably ok if you had a lot of leakage you will feel a tingle sensation in your hand if you are really worried take a small piece of foil and cover the crack that will prevent any radition from leaking, I used to repair microwave ovens and I know with the current models it is not possable for much to escape, unless there is a large hole I once serviced a commerial microwave that was used with most of the front glass missing, the user reported some tingling in his hand.
Nov 12, 2013 | Microwave Ovens
Door handle is cracked & would like to get it replaced. Can this be in house or should I take whole oven to service center?
Replacing a door handle on a microwave oven should be simple and requires no assistance from an appliance repair technician.
The door handle can easily be replaced on most microwave ovens by simply removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER.
If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Jan 29, 2010 | Microwave Ovens
The handle on the door cracked at the base. How do i replace this handle?
There are a lot of models that begin with JVM1660, however I have attached a breakdown of the unit so you can perhaps see what is involved with changing the handle. Hope i250t helps.
Nov 09, 2009 | GE JVM1660 Microwave Oven
FRONT GLASS DOOR HAS CRACKS
Sounds to me like the door needs to be replaced.
Jul 29, 2009 | Frigidaire FMV156DC Microwave Oven
Door handle replacement
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
Do not forget to rate the solution.
Thanks.
Feb 12, 2009 | KitchenAid KHMS155L Microwave Oven
Need to replace GE Spacemaker XL1400 door
On most microwavre ovens all you have to do is open the door all the way and lift straight up at the hinges. The door comes right off the hinge pins. In some cases you may have to remove the top louver panel (right above the door). You should NOT have to unmount the oven to complete this. In fact...I would not recommend it.
Is this a simple matter of replacing a door handle? If you need to only replace the door handle, you just lift slightly on the INNER door plastic around the glass and you will be able to access the door handle screws. There are a series of small grooves in the panel that you can use a small screwdriver to gently pry. You should not have to remove the entire panel. Just open it enough directly behind the door handle. Be careful when prying on the plastic. It can break if you're not careful. I hope this helps you.
Feb 27, 2008 | Microwave Ovens
Fan comes on when slight opening pressure is exerted on door handle.
The door frame and seal damage has put the relation of the door latches and the interlock assembly out of adjustment. If after disassembling the door it is found that the latch assembly is good, replacement of the door frame/seal might be all that is required to return the oven to normal operation. After reassembly, it is highly recommended to have the oven's emissions checked at an authorized service center for any leakage around the door seal area. The service center might also need to adjust and set the interlock assembly for correct operation also.
Oct 31, 2007 | Sharp R-1610 Microwave Oven
Broken Handle
On almost any microwave oven door if you open the door,on the inside part of the door,theres a square plate thats plastic that is a one piece unit that goes all the way around the edge of the door . That held on by little plastic clips that are molded right on the suround and easy to break, so take a small screw driver(of course the ovens unplugged by now) and start at one end and start prying it out inch by inch. Being care full not to crack it. If yop do crack it, you must replace it, but its not that expensive. Once you have off the cover surround, you will see the screws that hold on the handle. If you need help getting the part go to http://www.repairclinic.com as even if its not listed get the phone # and call them and they will assist you. Good Luck
Jun 03, 2006 | GE JVM1640 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
186 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
