Question about Sport & Outdoor - Others
Two sections of my fishing pole have become stuck together , how do i get them to come apart without breaking them ?
    President:
  • 1,776 Answers
That is a tough question and I can't make any guarantees, but I will tell you what worked for me once, if you promise not to laugh. I put the sections in a freezer for short periods of time and kept going and trying to pull the sections apart every little while. The cooling caused contraction and I was eventually able to get the sections apart. I told you not to laugh. Best wishes.
Posted on Oct 07, 2009
Does any one know if you can get replacement parts for a rocket fishing pole
I suggest you ask in the Fishing section . You are in the Chainsaw section
Apr 18, 2015 | Garden
Electric pole saw was put togeather wrong and can't take pole apart.
check for a small button in the connecting parts of the pole press it in and slip the parts
on reassembly make sure that that button lines up with a hole and clicks in
Sep 16, 2012 | Earthwise 10" Cordless Lithium Pole Saw
Do Carbon fiber hiking poles break easily?
Carbon fiber hiking poles are also quite strong. However, under high stress carbon-fiber poles become much more vulnerable to breakage or splintering.
Sep 04, 2012 | Coleman Camping, Backpacking & Hiking
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
Got the basketball poles stuck together and theyre not aligned
Dropping the stuck poles definitely WORKS! We had stuck basketball poles from a Spaulding 54 inch together wrongly. Dropped them on grass from shoulder height 4 times and they loosened enough to pull apart.
May 01, 2011 | Lifetime 3819 Impact 44" Basketball...
I have a disney princess tent that goes over a twin bed and i lost the instructions to putting it together and i need help.
  • 1
    Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space.
  • 2
    Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules.
  • 3
    Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body.
  • 4
    Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
  • Apr 22, 2011 | Toys
    I want to attach the chain saw to the pole
    ahhhg i would say NO if its made for a pole get the right pole ! you will find that the first time you use it you come back with just the pole and no saw.. and the you break you neck trying to retrieve your saw way up in the tree.. WHY U ASK ? the saw blade will get pinched . means stuck in the cut. and will need another saw to rescue it.. fun huh .if you need a little extra height use a truck bed. never use a ladder . good luck be safe..in the gas tank is a filter. you can use a clothes hanger to fish it out, remove it blow it it out backwards with air . or replace it. if this don;t work buy new fuel lines ,carb kit,carb cleaner spray(parts master #1736 my fav) and a new spark plug. when doing the carb just replace gaskets and diaphragm .. don't worry about all the other stuff in the kit, you are just washing the carb to get gunk or dust out of it .. all back together and wa la.. ning ning niiing.. back in biz.. one other thing that goes bad is the crank shaft seal( the 1 next to the clutch) and it can be a pain to replace ! vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
    Aug 08, 2010 | Remington Electric Pole Saw
    Lifetime Portable Basketball System- The pole are stuck.
    Deddy456 was spot-on with dropping the poles from waist level. Worked for our Spalding that looked hopeless. Thanks!
    Jul 04, 2010 | Lifetime 3819 Impact 44" Basketball...
    Disassemble a La Cie Porsche-design external CD burner case?
    I just pulled one apart. You're not going to get it to work unless you pry it apart on the bottom. the parts are stuck together with 2 sided tape. use a thin, flat bladed screwdriver to pop it apart. i did this with relative ease, and it worked alright. didn't trash the plastic too badly either.
    Dec 15, 2009 | LaCie Computers & Internet
    How do I put together the pole caddy (4 shelf) with spring? did not come with instructions.
    Put the poles together eith the spring section on the top. Otherwise, the weight of what you put on it will pull it down.
    Jan 07, 2009 | ZENITH/BATHWARE 2114S CHR Wire Corn Tub...
    Sport & Outdoor - Others Logo
    413 people viewed this question
    Top Sport & Outdoor - Others Experts
    Bill Eager
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
