Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Proper procedure to adjust valves on Briggs and Stratton, Vanguard Model 385777, type 0349-E1 engine
  • 472 Answers
YOU HAVE TO REMOVE THE PLUG AND ROTATE THE MOTER TO T D C THEN TUR IT HALF PAST THEN CK THE VAVEL CLARENC ARE YOU SURE THIS IS THE PROBLEM TELL ME WHAT ITS DO ING SO I CAN MAKE SURE THATS THE PROBLEM LET ME KNOW
Posted on Oct 07, 2009
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Engine won't stsrt as starter won't wind over past compression stroke. starter and battery good
check your valve adjustments, quite common for this to happen when the valves go too far out of adjustment.....it will work better with them adjusted too
Jan 27, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 23 hp Briggs vanguard engine-V Twin Model 380447/type 76-E1 code 4241. The engine is less than two mowing seasons. The engine will not turn over properly and I have used another start I have and...
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
Sep 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Engine wont start
go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Apr 23, 2010 | Briggs & Stratton 66set Panzer Tractor...
How to change electric starter on vanguard 14 hp v twin vertical shaft.
Please, help me to regulate valves on Vanguard B&S 14HP OHV model:294446 tip:1141-a1. I don't know how. Thenks. My adress kolya-kolyanof@rambler.ru
Mar 31, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Trying to find starter for 12.5 vangard v twin motor. my model number is 9108304 on starter but can't find anything the same.
anytime you deal with small engine parts you MUST be armed with the engine model number, code and type. on late briggs these are on one of the valve covers.
Feb 08, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Oil in air breather
sounds like you have too much oil in the engine (should normally be around 500-600ml when there is too much oil, it gets past the piston rings and pushes it through to the head.
May 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
425 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
