Question about NEC VT47 Multimedia Projector
Audio Jack of NEC VT47 (using external speakers)
There is an audio jack in the back of the NEC VT47 but when I plug in working speakers, nothing happens. The audio still is projected from the NEC internal speakers. I know the speakers work on several other machines with no problem. The speakers are plugged in and working. The issue seems to be with the jack itself. Is there a way to replace or fix this? The internal speakers on the projector are not loud enough for my classroom.
  • 70 Answers
Go to your menu find the volume settings. i think your volume is 0 or muted.
Posted on Oct 08, 2009
Audio jack output not working when using plug in external speakers for my NEC Versa P8310 laptop how do i resolve this what realtek driver supports this system
The Windows control panel is where you should look, under sound. You can then select the output. If you are plugged into the audio output jack it will not recognise any particular speakers, so does not need a driver.
Oct 10, 2014 | Computers & Internet
No volume on 52 inch aquos when volume is pushed a picture of a mini plug shows
Check your external speaker jacks for a foreign object that maybe a child could have put in it or if you using external speakers check these for bad connections. The set thinks that you have a jack plugged in so it is either a bad jack, or a bad audio card or something is causing the jack to short itself like a piece of metal in the jack. Also check you audio settings so that you have the tv's speakers selected and not an external jack.
Aug 05, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I am only hearing audio out of my left headphone speaker when plugged into the Tascam US-122. how can I play back my tracks and have the audio fill both speakers?
you might be using a mono output jack or input jack.....check the jack end...1 ring = mono / 2 rings = stereo
make sure your sending a stereo signal in, then check the L/R balance.
Jul 06, 2011 | Tascam US122 Audio/MIDI Interface with...
It says, that the ViewSonic PJD5122 SVGA DLP Projector has a built in 5 watt speaker. Does it? Because when i try to hook my xBox into it, there is no sound when the voume is all the way up. Also, when I...
You have a 3.5mm Audio Input jack for external audio in. ( Not Speakers) The Audio Output jack is for connecting that to a stereo system which is the best way to go. So, what you want to do is connect your xbox audio out which is probably a rca jack to the projector. I believe you will have to buy a y-adapter ( 3.5mm male > double rca fe-male) then use the standard rca audio cables. You don't plug speakers into that unit, I hope you haven't damaged the audio circuit. You might have a external audio switch within the menu of the projector to switch from internal to external audio source,,, look for that.
Dec 03, 2010 | ViewSonic Televison & Video
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Apr 19, 2010 | Creative Labs I-Trigue L3800 Computer...
How do I get two external speakers to work?
you may need to have powered speakers to hear them - - lots of pc's need powered speakers because the onboard audio is so low
Apr 01, 2010 | HP Pavilion a1730n PC Desktop
Bearcat BC144XL Scanner ~ no sound
Try it with an external speaker. The external speaker jack receives the audio from the scanner before it goes to the internal speaker. If the jack thinks there is still something plugged into it, the audio to the internal speaker is interrupted. If the jack is stuck, it may still work with an external speaker.
Aug 30, 2009 | Uniden BC248CLT Base Scanner
Stereo Speaker troubleshooting
It sounds like the audio jack itself has internal damage. Depending on how it is mounted on your laptop case, or possibly on an internal circuit board inside the laptop; it might be possible to repair the jack or replace with a new 1/8" audio jack. Some soldering skill may be required after disassembling the laptop and getting access to the jack.
Jan 12, 2009 | Computers & Internet
Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
Jul 01, 2008 | Dell Inspiron 6000 Notebook
NEC VT47 Multimedia Projector Logo
193 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
