Question about Brother ML-100 Typewriter
Ribbon problem Brand new ML-100 and when typing, the ribbon doesn't automatically advance. It appears that the gear underneath is turning and the wheel on the ribbon is moving but the ribbon itself usually stays in the same place. Any ideas would be greatly appreciated.
  • rcarp514 Dec 29, 2007
    Ribbon does feed by hand. Ended up feeding quite a bit of the ribbon manually and now it appears to be working. Hope this was a one time thing as it doesn't seem to be very cost effective paying for a full ribbon and only getting to use 2/3 of it. Thank you.
  • Brother Master
  • 3,594 Answers
Does the ribbon feed by hand? If not get a new ribbon.
DickyO
Posted on Dec 28, 2007
My Brother ML 100 typewriter does not print because the film ribbon does not advance while typing. It keeps striking the same spot on the ribbon and therefore, no typing appears on the paper. If I remove...
I've had several of these ribbon cartridges do this. You might get lucky and get it freed up, but I rarely did. Look in the windows of the cartridge and see if the ribbon is not wound evenly...if it isn't you can try gently tapping the cartridge on a flat surface to attempt to even out the ribbon on the spool. If you are not successful, then replace the cartridge. I had mine for almost 10 years and the cartridge was always the problem. Otherwise the typewriter worked flawlessly. Good luck.
Sep 05, 2013 | Brother ML-100 Typewriter
I just replaced the typewriter ribbon my Brother ML-100 typewriter; however, it does not advance properly so typing does not appear on paper. What is the problem?
Take the ribbon off, see if it advances with the hand feed wheel if not you have a bad ribbon. Type without the ribbon and be sure the ribbon driver is turning. There may be a switch or setting for use of an overstrike ribbon,
DickyO
Aug 28, 2013 | Brother ML-100 Typewriter
The ribbon will not index forward on my 345 DLE. It appears that the shaft that inserts into the cassett does not turn to move the ribbon.
if the knob on the ribbon cartridge doesn't move the ribbon when you turn the knob the direction of the arrow (on the cartridge next to the knob) you need a new ribbon
Nov 03, 2011 | Smith Corona Wordsmith 100 Typewriter
Replaced ribbon but now the ribbon doesn't advance. Could it be ribbon itself is defective or could I have replaced it wrong? Ribbon is wrong replacement?
Try removing the ribbon, advancing it a foot or so by hand. Install it, mark the feed wheel type and see if it is turning.
DickyO
Aug 02, 2011 | Olympia Monica 2 Typewriter
Just installed new ribbon cartridge and still cannot get anything typed. worked fine three days ago.
If it worked befor you installed the ribbon then check the installation or if the ribbon is very old it may be bad. Try typing on a multipart form and see if the carbons print.
Go to brother.com, click on support, poke around a bit and you will find a downloadable users manual.
DickyO
Jun 29, 2010 | Brother ML-100 Typewriter
The ribbon won't click into place. It advances to
Go to brother.com, click on support you can download a manual there. The ribbon must be all the way on to complete the power on sequence.
DickyO
Apr 13, 2010 | Brother ML-100 Typewriter
GX-6750
The ribbon doesn't advance at all? Try turning the ribbon by hand. If it is really hard to turn, or doesn't advance when you turn the knob (make sure you turn it in the direction of the arrow), then the ribbon is defective and you just need to get a good one.
If the ribbon turns easily, the leave the ribbon off, type and watch to see if the black knob on the left of the ribbon plate (the place where you put the ribbon), that turns the ribbon, is moving.
Also I have found that some brands of ribbons simply do not work on this machine. If the ribbon and the ribbon drive is working, try a different brand of ribbon.
Oct 22, 2008 | Brother GX-6750 Typewriter
Corona 100 typing ribbon
Either a jammed ribbon or feed gears. Try another ribbon or get it serviced.
Jun 14, 2008 | Smith Corona Wordsmith 100 Typewriter
Ribbon is sticking
You may have a wrong ribbon, sometime the small parts where the ribbon turn gear goes into does not match up correctly. Can you turn the ribbon manually by hand, if the ribbon does not turn it will not type....
Apr 17, 2008 | Brother ML-500 Typewriter
Brother ML-100 Typewriter Logo
123 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
