Question about Kenmore Freezers
Upright Deep Freeze Stopped Working
We have an older deep freeze in our garage. Two weeks ago our hot water heater went out and leaked all the water out in our garage. The water ran under the deep freeze. That afternoon while waiting on the plumber I notced the freezer sweating then opened it and it was starting to defrost. I assumed that the water that ran under it messed it up. I also noticed that it kept kicking on and then right back off again. I unplugged it and thought it needed to dry out underneath. I've plugged it back in and it is doing the same thing. The blower on the inside is going full blast but is warm now and it is still kicking on and off. Is it a total lost? My husband thinks it is gone. Any thoughts? Thanks!
    Sergeant:
  • 314 Answers
The compressor relay is gone For a few dollors you can still save it.
Posted on Mar 28, 2017
  • 25 Answers
SOURCE: hotpoint 25.3 cu. ft. not cooling
When the freon as been recharged, did the dryer been replaced?
Posted on Nov 26, 2007
the dr
  • 447 Answers
SOURCE: Up right Amana Deep Freezer
Try taking a small piece of solid copper wire strand, loop over defrost heater and extend into drain hole, this is a trick we use to help with this issue by bringing a little heat around the hole. The freezer may be manufactured by Woods Inc, a canadian appliance builder. These did have lots of problems with the water building up between the inner and outer liners, Not much you can do with these either to totally resolve this issue. Make sure the water is going into the drain pan when you pour the hot water.
Posted on Jan 01, 2008
  • 90 Answers
SOURCE: GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Posted on Feb 09, 2008
SOURCE: deep freezer drain
drain hole block-up. u need to defrost freezer
Posted on Apr 15, 2008
22yooper
  • 828 Answers
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Posted on Jun 10, 2008
Frigidaire upright freezer ice forming in bottom and leaking not freezing ice cream
This does not sound good because the breakers tripping may indicate a compressor windings short. Have someone do the test below,
Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Feb 07, 2013 | Frigidaire 20 cu. ft. / 566 liter Upright...
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
Deep Freeze not freezing
this could be from a faulty temp controller however my best! bet is it's low on froen due to a high pressure leak
Jan 17, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
How to uninstall deep freeze from your pc?
how yto uninstall deep freeze, password forgotten
Mar 21, 2009 | Amana 16.8 cu. ft. / 476 liter Upright...
My deep freeze outside will not stay cold.
a freezer is just a heat pump . from inside the freezer to the garage . the first law of thermodynamics says heat travels from a hotter to a colder surface . it could just be the cold how much are we talking?
Dec 14, 2008 | Kenmore Freezers
Top half not freezing
If this is not a frost free unit , it probably has a freon leak. This is usually not worth fixing in a deep freeze. If it is a frost free unit the fan could be bad. This is an easy repair.
Mar 26, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Feb 07, 2008 | Freezers
Freezers Logo
396 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
