Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher gu2700xtsqI does not cycle timer stuck on 1 minute
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Mod DP1040XTXQ6 clean light does not come on
If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board
God bless you use the VOM..
Apr 05, 2013 | Whirlpool DP1040XTX Portable Dishwasher
Dishwasher was fine till i put it on a full cycle then it went bang twice ..what as gone ?
Float Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/control electronic. Use the VOM
Apr 05, 2013 | Dishwashers
Dishwasher stuck in wash cycle
see this causes and fix it. God bless you
.Float Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control 10_17_2012_1_06_02_pm.jpg
Oct 16, 2012 | Whirlpool Dishwashers
Maytag dishwasher starts too easily and gets stuck in wash cycle
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Sep 28, 2012 | Maytag MDB7100AWB Dishwasher
Need reset sequence for dishwasher
see this causes, use the common sense.God bless you
Dishwasher Stuck in a Cycle If your Dishwasher is stuck in a cycle check the following
Float Switch
Timer / Control
Sep 19, 2012 | Whirlpool DU1055XTS Built-in Dishwasher
Hotpoint dishwasher. Is the timer out?
maybe the float is sticking. did you check the float switch?
Aug 19, 2009 | Dishwashers
Dishwasher will not run through its cycle
Hi
If the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
720 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
