Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
I'm getting eight flashes. What does this mean?
What does it mean when your obd2 is flashing four eights
On Board Diagnostic (OBD) Readiness and Drive Cycle ... - Ohio EPA epa.ohio.gov/Portals/27/echeck/docs/OBDReadinessDriveCycles.pdf
  1. Cached
  2. Similar
If possible, when working on a vehicle either before or after an E-Check OBD II test; do not clear the. Diagnostic Trouble Codes ... 4. Drive for at least 20 minutes in urban traffic with at least 4 idle periods ... indicator blinks eight times, it means that the vehicle is not ready for E-Check; if the service engine soon indicator stays ...
Mar 29, 2018 | Cars & Trucks
What does eight flashes of the wrench indicator mean on the invacare Pronto m 41 power chair
A flash code of 8 indicates a computer controller problem. Check all the connections at the controller under the rear cover. A rebuild or replacement of the controller is probably necessary. Hope this helps.
Jun 10, 2016 | Invacare Health & Beauty
Jazzy select. quick operating cutoffs locations,when i hook up the chagrer. the lever control blikks eight times and then quits cant find an opening or a short. i need a copy of the wireing schematic. .
Hi. On some machines eight flashes is a fault code for a faulty motor. Usually means that the brushes have stuck or worn out. Use a multi-meter, and see if both motors have a circuit through them. Good luck. Neil.
May 16, 2010 | Pride Jazzy Select 6 Indoor Power...
Light kee flashing orange/green and says computer is busy when there is nothing in print queue
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 29, 2010 | Canon BubbleJet i320 Printer
Printer stopped working. Getting "10" orange flashes for which there is no error answer in the book. Believe driver is up to date. Wondering if I should uninstall program and reinstall. Problem may have...
Mar 27, 2010 | Canon i860 InkJet Photo Printer
Set of 4 alternating orange and green flashes. No carriage movement when opening lid. All started with waste ink tank issue and then trying multiple 'fixes' from online
Mar 26, 2010 | Canon BJC S600 InkJet Printer
The orange light keeps flashing
Mar 22, 2010 | Canon I990 InkJet Photo Printer
Activate pairing mode
Holding down the multifunction button for eight seconds puts the unit in pairing mode and an LED lets you know the status of the headset. Flashing blue and red means the H4 is in pairing mode, flashing blue means it is paired and flashing red means the H4 needs charging.
Aug 10, 2008 | Cell Phones
Tv shuts off by itself then flashes a code 8 blinks
Eight blinks means, "High voltage error". The probable cause location listed is "T8005 is faulty (D board). T8005 is the fly-back transformer (FBT). or you can replace the full d-board
You may purchase the D board complete for $185.10
or send in for repair here
if one of the crt is shorted it can also cause this problem.
Jan 30, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
