Question about Maytag MED5600TQ Electric Dryer
I just moved to a new apartment and y dryer runs but is not heating up at all
    President:
  • 1,776 Answers
Check for a blown thermal fuse or a faulty heating element. Both components should be located inside the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty component. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 07, 2009
Dryer won't start
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
Sep 03, 2012 | Maytag Dryers
Dryer not heating and timer dosen't move
A dryer runs 2 halfs (one half 120, the other 120). Sounds like you are missing the 120 that operates those two. Did you change from a four prong to a three prong?
Jun 02, 2012 | Whirlpool LEB6200 Electric Dryer
Dryer was running longer than we thought it should. Now timer will not move and it does not dry the clothes. Could this be a switch problem or a heating element problem
Check your vent outside of your home or apartment. If you are not feeling anything heat or air, then it is clogged. Clean the vent and it should be alright. If you had on the sensor dry that could be the reason why your timer wasn't moving.
Apr 30, 2011 | Roper Dryers
Dryer does not heat. checked vent and it was clogged. we cleared, but it still won't heat
thermal fuse is blown. unplug dryer and take apart back of dryer, tape the two wires together, start dryer it should heat, if it does then you will need to order a new thermal fuse, do not run dryer like this as it will start a fire, this bypass is for test purposes only. Hope this helps Tim:
http://www.dryerpartsonline.com/Kenmore-Dryer-Thermal-Fuse-3392519_p_11.html
Apr 24, 2011 | KitchenAid KEYS750LQ Electric Dryer
Dryer is running but not heating. Looking for reset button. Can't find it.
if the dryer is running but not heating, then it has to do with the heating element or the thermofuse. You will need to take the dryer apart:
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) look to the right back of dryer, it looks like a spring in a metal box disconnect and replace.
Hope this helps Tim
Sep 25, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I have used tedx640eq0 whirlpool dryer. Just moved into a new apartment that had a 3 prong plug. I connected the 2 hot's and put the ground on one of the ground terminals at the new 4 prong socket that I...
The reason for the 4-wire plug/socket system is that in the older 3-wire units, cabinet 'ground' was actually 'neutral' carrying current for the 115 volt parts of the dryer, while the two 'hots' were supplying 230 volt power for the heater and motor. This allowed a voltage difference between the dryer cabinet and true ground. How did you wire 3-wires (coming from the apartment electrical panel) into the 4-wire dryer socket? Dryer cabinet ground should go to true ground at the electrical panel, and dryer neutral should go to electrical panel neutral. Did Whirlpool violate the separation of 'neutral' and 'ground' when the machine was made (did the timer neutral connection go to cabinet ground instead of machine neutral or is the timer motor stuck)? Your dilemma would be answered by having the apartment owner hire a licensed electrician to upgrade the dryer service to 4-wire specifications. The ground to neutral connection you mentioned may make it work, but you will wind up with the 'hot' cabinet condition that the 4-wire setup was supposed to alleviate. Hope some of this helps!
Jun 04, 2010 | Whirlpool TEDX640PQ Dryer
My dryer is running but it doesnt producing any heat. The dryer has air moving thru the system and the timer but no heat? it worked yesterday
One of three things is your issue.
1. Thermal fuse is bad
2. Thermistor is bad
3. Heat element is bad.
This is a newer type dryer that probably has control board also. Probably gonna need a service tech to come inspect unless inside parts are like an older style dryer.
Old dryers are easy to fix, but these new ones have parts like a computer in them making it harder to take apart and fix unless you have technicial background.
Make sure your lint trap stays clean all the time, this is usually the cause of one of the three parts above to go out prematurally.
Hope this helps
TankMurdock
Apr 27, 2009 | Maytag Neptune MDE6700A Electric Dryer
Amana Dryer will not work,will not stay on,makes funny noises
during the process of moving your dryer, it sounds like the drum became dislodged. With the dryer off, open the door and try to move the drum by hand, if it sounds like something is 'dragging' them the drum is off its bearings. IF it is, the quickest way to get help to take it apart is go online to youtub, type in your dryers name and model number and ask how to replace drum
Apr 27, 2017 | Maytag MDE2706 Electric Dryer
Damp clothes
the dryer is not the problem the problem is the house vent it is restricted some where
May 02, 2008 | Whirlpool LER6636PW Electric Dryer
I have a whirlpool duet electric dryer and I just moved into a new apartment. The dryer powers on and works fine but there is no heat. do I have to replace the thermostat?? Please help
First check to see if you have 220-240vac potential at dryer service. The motor could start and run on one leg and no heat due to other leg open. If you have full potential, moving the dryer possibly could have fractured brittle used heating element string. If you are not capable of electrically troubleshooting a visual inspection might reveal open element.
Apr 16, 2008 | Dryers
Maytag MED5600TQ Electric Dryer Logo
52 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
