Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Keyboard not working on Laptop but the mouse is
  • 165 Answers
Install the keyboard driver then it will be ok
Posted on Oct 07, 2009
Lg laptop model lgr40
Try to load laptop in safe mode. If keyboard and mouse works in safe mode - then you'll need to clean your system, it has viruses.
Sep 24, 2013 | MSI Computers & Internet
Acer 5570z keyboard is locked..Mouse works fine. Tried it in safe mode..keyboard still wont work..but mouse will...Even reloaded the operating system and keyboard still doesnt work..
Hook an external keyboard to the laptop, if okay! replace the laptop keyboard. If no change check bios setting to make sure the laptop is not disabled, and reset bios to factory default.
Mar 10, 2012 | Acer Computers & Internet
Laptop Touch Pad will not work
if you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Jul 10, 2010 | Acer Aspire One PC Notebook
I purchased a HP laptop, Windows 7. I installed
You have to install the software that came with the wireless mouse. I have several, and some will and others won't work without the software. That is 90% what it is.
May 17, 2010 | Logitech Cordless Mouse
Just changed batteries in my wireless mouse.
there will be a button on your mouse. Press it to sync the settings with your laptop and it should start to work.
or else
click start
right click my computer
properties
hardware
device manager
?mouse and keyboard
scan for hardware changes
Feb 26, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard sticks .and also the mouse will jump into another
hi friend,
Erratic Mouse
  1. The solution for an erratic mouse involves going into the registry on Windows. Backup your registry files. Never make changes to the registry without doing this. Go back into the registry. Go to the editor. Locate the key phrase that reads: hkcu---control panel---mouse. Delete this line from the registry. Close the registry editor. Shut down your laptop. Wait for 5 minutes. Reboot your laptop. Windows will create a new registry key for you. This should solve any erratic mouse problems.
  2. Mouse Not Found on Laptop Boot Up
  3. The laptop mouse is plugged in. You boot up your PC. The mouse isn't found. Chances are the mouse cable came slightly unplugged. Unplug the mouse. Re-plug the mouse into the laptop port. The laptop should recognize the mouse. Reboot the laptop if it is still not working after you check the cable.
  4. Mouse Moving Slowly
  5. A laptop mouse that is moving slowly is probably dirty. This type of equipment is prone to collecting dust and dirt. It's like a magnet for dirt. The solution is to clean the laptop mouse. Unplug the laptop mouse from the computer. Remove dirt particles from the optical mouse with a pair of tweezers. Make certain the eye area is clear. A small piece of debris can cause an optical mouse to move slowly. Remove the ball from the mouse, for a standard mouse. Wipe the ball with rubbing alcohol. Wipe the inside of the mouse with a dry cotton swab. Remove all debris and dirt. Replace the ball.
  6. General Mouse Tips
  7. Clean the work area where you will use your laptop mouse. This will reduce the amount of dirt that collects in the mouse.
    Work in areas that don't have high traffic for pets. Sitting with your pet cat or dog in your lap and using your laptop is not a good idea. The laptop mouse will attract and catch pet hair and dander, requiring you to clean it more frequently.
    Wash your hands prior to using your laptop or your laptop mouse. This will keep the equipment cleaner to make it last longer. Less maintenance will be required for both the laptop and the laptop mouse.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); instructions for sticky keyboard: Step 1 Soak up spills immediately after they occur. This not only reduces the risk of damage, it prevents much of the fluid from spreading beneath the keys. Use a towel, cloth or anything else you have handy at the moment.
  • Step 2 Unplug the keyboard from the computer or disconnect the power supply if you are using a laptop keyboard. Make certain nothing else is connected to the keyboard and unplug any USB devices.
  • Step 3 Pop the keys off your keyboard using a dull knife or flathead screwdriver. Do this slowly and carefully to avoid damaging the keys or the keyboard.
  • Step 4 Place the keys in a bowl full of warm soapy water, and let them soak for 20 to 30 minutes. Dish detergent is effective at removing dirt, oil and stickiness.
  • Step 5 Use a damp, lint-free cloth to wipe the large areas of the keyboard. A cotton swab can be used in smaller spaces and around the edge of the keyboard.
  • Step 6 Set the keyboard aside, upside down, on a towel and leave it to dry for several hours. This will also allow any trapped fluid inside the keyboard to drain out.
  • Step 7 Wash off any remaining dirt, oil or debris from the keys. Use a cotton swab to clean inside of each key, if necessary. Rinse the keys very well with warm water and set them on a towel to dry.
  • Step 8 Replace the keys once the keyboard and keys are fully dry. If your keyboard is still sticky, fluid likely leaked deep inside the keyboard. You can attempt to clean the internal part of the keyboard by yourself, but this will void the warranty and risk further damage. Either purchase a new keyboard or send yours to the manufacturer for repair.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Using a can of pressurized air to clean your keyboard will remove any loose dirt and debris but will not get rid of stickiness or oil residue. Take a photo of your keyboard before removing the keys to make replacement easier.
    hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Computers & Internet
    Acer aspire laptop mouse and keyboard not working
    1. first check the bios.
    2. you can use serial mouse or keyboard change this parallel mouse and keyboard.
    Mar 29, 2009 | ASUS P5PE-VM Motherboard
    How to deactivate internal keyboard - Dell Inspiron 9400
    if you go to the control panel, to hardware, in the keyboard section you should be able to uninstall the internal keyboards driver which will stop it working.
    Mar 22, 2009 | Dell Inspiron 9400 Notebook
    Laptop keyboard not working in compaqv3000.
    i reinstall all the driver of my vista laptop drive especially bios and restart my computer and this solve my problem.
    Feb 11, 2008 | Compaq 310640-001 Keyboard for Presario...
    Fujitsu Siemens AMILO Pro V2000 Notebook Logo
    206 people viewed this question
    Top Fujitsu Siemens Computers & Internet Experts
    Lee Durbin
    Lee Durbin
    Marcin
    Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
