Question about Linksys Wireless-G WRT54G Router
Router computer does not recignise router is hooked up
  • 556 Answers
Try the following
Click Start then All Programs then Accessories then Command Prompt A new window will open
I suggest trying this wired (turn off wired adapter and then wireless
Ping 192.168.1.1
If this command times out 4 times you are not connected to the router.
If it does not time out you are connected to the router.
Then when the ping works -- if you cannot connect to the internet you may be missing DNS Addresses
From the same Window enter -- (1 space before /)
ipconfig /all
You should see in the lines of data that follow the ip address like 192.168.1.?, the subnet mask 255.255.255.0, the default gateway (router address) 192.168.0.1 and if there are no DNS addresses you either need to configure them into the router (generally preferred) or configure them onto the adapter -- network connection -- Internet Prorocol (TCP/IP).
If that does not fix the internet you probably have probably failed to meet the internet service providers requirements for the WAN/Modem side of the router. These can often be found on the ISP support or help site. IF your ISP is a Telco -- you MAY need to configure PPPoE (and "bridge" their modem/router), cable based ISP's less often have requirements for the WAN side of a router.
PS with wireless communications you should consider encryption. This is a protection from others accessing your network and any files that mau be in shared folders.
Leave a comment to this message indicating what you know and where you could use help I will continue to respond as necessary.
Posted on Dec 24, 2007
    Sergeant:
  • 239 Answers
Do you have your wireless on in the computer. I need more info, you should be able to go into your network setting and enable your wireless there, or in the control panel also under wireless networks, Try that and if it don't work give some more info plz. Thanks
    Brigadier General:
  • 6,966 Answers
If this is a new installation/set-up, you need to run the Installer CD that came with the router.
If your are adding to an existing network that is already running/working:
1. try running the new/additional PC using lan cable instead of WiFi initially for the configuration;
2. Verify that the new PC do get an IP add from the DHCP server (which is also the router); or
3. Static assign IP add to the new/additional PC based on what your network is using. Example on the new/additional PC: IP Add 192.169.1.200; Subnet Mask 255.255.255.0; Default Gateway 192.168.1.1; DNS whatever your ISP/Router is using;
4. Verify what WEP/WPA security/key your network is using and that is also configured in the new/additional PC.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
good luck and kind regards.
There's no place on modem to hook router
Look for Ethernet jacks. You want to hook both your computer and your daughter's laptop to the router to out ports i.e. usually on the front side. The back side of router would hook using probably another Ethernet jack to your modem.
Jul 02, 2010 | Belkin (F5D7230-4) Router (587009)
I have 3 hard drives in my acer that are recignised in bios but only the master is appearing in my computer. How do i make them all appear??
Short and quick if the bios can see them but your operating system can't, chances are that either the format is wrong or the disks are not formatted at all.
In windows go to control panel
Administrator tools
computer management
disk management
This will bring up all the hard drives, logical drives and any other type of drive that you have hooked up. Find the drives you are looking for see if the operating system can see them, if it can it will tell you what the format is or even if the disk is formatted. From there you should be able to find your way.
Hope this helps
May 31, 2010 | Acer Veriton 5100 PC Desktop
I cannot get a connection to the internet now.it keeps saying ip address not recignised
Your Router or Modem gives you that IP Address. Reset and Power down everything including your PC. Restart with Modem First...wait 10 sec start Router if you have one... the 10... start PC
Dec 31, 2009 | Computers & Internet
Hook up router and can't access internet from wired computer.
Sometimes the modem-computer-router not "sync" together.
Try this.
1-hook the computer to modem. Internet yes? good.
2-hook the computer to router and check you IP. If it like 192.168.1.2,
the router's DHCP is working.
3-reset router to default setting.
turn off all and turn on modem, router, computer.
keep me posted.
Jul 06, 2009 | Belkin (F5D7231-4) Wireless Router
My computer won't recognize my mp3 player(samsung yp t9)
it depends on the computer if your using a portable computer macs seem to not be able to recognize them but my dads pc can recognize it. good luck
Feb 23, 2009 | Samsung YP-U3 MP3 Player
Linksys WRT300N router issue
you have to power down all three items , turn on the computer then the modem then the route if this fails hit the reset button on the modem this shoul work for ya
Dec 25, 2008 | Linksys WRT300N Wireless Router
My Lacie hard drive is not working
It Seems to me like when you unpluged it without properly ejecting it, that it partly corrupted the part of the ext. hard drive that is recignised by the pc to then recignise it and make it ready for you to use.
If it uses a power adpter to power it plug that in first, then plug it into you computer, and see if that works.
I hope I helped.
Yours,
cjpipod
Dec 05, 2008 | LaCie (300740) 160 GB Hard Drive
How to hook up my router
Hi Ashley
Are you trying to hook the router via wireless or via network cable
is the router working with the computer in the living room?
Cheers
petermac181
Nov 20, 2007 | NexxTech 4-Port Ethernet Broadband Router...
Linksys Wireless-G WRT54G Router Logo
105 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
