Question about Quantaray QSX-DigiPro 8500 Tripod
Stripped hinge The horizontal to vertical adjustment wing screw assembly is stripped. i wanted to replace the the insert that has the threads.
Wing mirrors will not adjust
Wing mirrors have a certain range of electrical adjustment. Manual adjustment by pushing with fingers can make electrical adjustment inoperative. The solution is to make finger adjustment to get back to the electrical range.
May 22, 2016 | Cars & Trucks
Tip
How to adjust AUDI headlights beams
There are two adjustment points (screws). For example left headlight: you will see one point near the end of left wing, at bottom side through a wing hole. This is for vertical plane headlight beam adjustment (up-down). Another one point is against water radiator side. This is for horizontal plane headlight beam adjustment (left-right).
on Dec 18, 2009 | Audi A4 Cars & Trucks
How do you remove the headlight assembly on 1995 ford f250?
  • 1.
    Remove the two upper screws from the headlight housing, using a Phillips screwdriver.
    Locate the two lower retaining nuts inside the engine compartment at the bottom of the headlight housing. Remove the nuts using a ratchet, extension and socket.
  • Separate the turn signal and marker light assembly from the front grill. Rotate the bulb holders counterclockwise and pull them out of the assembly. Set the assembly aside.
  • Unplug the headlight bulb connector from the bulb. Rotate the retaining ring counterclockwise one-eighth turn and remove it from the housing. Pull the headlight bulb straight back and out of the housing. Do not rotate the bulb during disassembly.
  • Lift up on the headlight housing retaining clips to unsnap them from the headlight housing vertical adjuster studs.
  • Locate the horizontal adjuster at the outer bottom corner of the headlight assembly inside the engine compartment. Loosen the horizontal adjuster until it is free of the adjuster nut.
  • Remove the headlight housing from the vehicle.
Installation
  • Install the headlight housing in the front grill.
  • Engage the horizontal adjuster screw with the adjuster nut and screw it partially in.
  • Snap the headlight housing clips on the vertical headlight adjuster studs.
  • Insert the headlight bulb into the headlight housing, flat side up. Slightly rotate the headlight bulb to engage the grooves in the light with the alignment tabs in the back of the housing. Install the retaining ring on the bulb. Plug in the headlight bulb connector.
  • Install the bulb holders in the turn signal and marker light assembly. Install the assembly in the grill. Install the two upper screws, using a Phillips screwdriver. Install the two lower retaining nuts, using a ratchet, extension and socket.
Headlight Aiming
  • Pull the vehicle to within a few inches of a blank wall, on a flat surface. Apply two strips of tape to the wall vertically to mark the centers of the headlights. Apply a strip of tape to the wall horizontally to mark the center of the headlight height. Back the vehicle up 25 feet in a straight line.
  • Turn the headlight low beams to the "On" position.
  • Adjust the vertical headlight adjusters until the high-intensity zone of the light pattern is two inches below the horizontal mark on the wall.
  • Adjust the horizontal headlight adjusters until the high-intensity zone of the light pattern is two inches to the right of the vertical headlight marks on the wall.
Nov 08, 2012 | Cars & Trucks
My headlights on my 1996 Buick Roadmaster need adjusting, do you know what adjusting screws make it go up & down or in or out? I'm having a difficult time seeing the lines on the highway. How can I...
Look for a pin on top of the headlight assembly and for another on the side of the assembly, near the mid-line of the Buick. The top pin controls the vertical alignment of the headlight, and the side pin controls the horizontal alignment.Insert the screwdriver into each pin and twist to adjust the headlight beam .Be careful not to over-tighten.Its like a screw.------------- This will help.Thanks.Helpmech.
Dec 24, 2010 | 1996 Buick Roadmaster
Were do you adgust headlight on 2001 vfr 800 f1 as mot says not right thanks
there are small holes on the upper black cowl, you will need to insert a long  X-head screw driver in there. Turn for horizontal adjustment
There are two more slots on the headlight assemble - which can be accessed from under the front cowl. X head screw driver or a 8mm spanner can be inserted. Turn for vertical adjustment
Jun 23, 2010 | 2001 Honda VFR 800
I am trying to change a headlight. I can't can not
The headlight assembly (1993 Grand Caravan) is held in place with three plastic "wing nuts" that rotate on the ball-end (front end) of the adjusting screws. One "adjusting screw" (the one on the bottom, inboard side) is not for adjusting, just for mounting. The other two adjusting screws take a torx T15 in the front end of the screw.
Removing the headlight assembly is somewhat of a trick - it seems like it takes a special tool to reach the "wing nut" and turm it 1/4 turn (90 degrees) CLOCKWISE (so the "wings" are vertical). When all three of these mounting "wing nuts" have the wings vertical, the headlight assembly just pulls forward and off these mounting nuts. Place the new assembly back over the "nuts", turn the 3 "wing nuts" another quarter turn, and the new unit is mounted. Probably not even a need to re-adjust the headlights, but you should check.
The PROBLEM, is that it appears to take a special tool to reach and turn these wing nuts without breaking them (yes, the old ones get brittle). I tried a socket (did not work), and then long needle-nose pliers (broke one wing nut), then a 1/2" open-end wrench (which at least worked). However, pushing the new assembly back over the wing nuts, I broke another wing nut. So, I broke 2 of the 6, and one was broken when I started.
Now I need to find replacements for these "wing nuts" ... any ideas where to get them?
Of course I can use some washers, some nuts to fit the fine-threaded adjustment screw, and some sort of bushing (maybe cut a short piece of rubber tubing to fit over the adjustment screw). Place double nuts (second nut to lock the first in place) and a washer, then the bushing onto the adjusting screw, then the headlamp assembly onto the bushing, then add another washer, and two more nuts (not too tight) to lock it onto the adjusting screw (which must still be free to rotate). Repeat for each of the 6 mounting points. I have not tried this yet, but ... it should work.
Fabricate a tool to turn the "wing nuts" using a piece of 3/8 inch ID tubing which you file or cut 1/8 inch by 1/8 inch notches on each side of a diameter line.
Apr 22, 2010 | 1993 Dodge Caravan
I Have an Audi a4 Quatro 2004 model. Adjust Low Beams?
Nov 19, 2009 | 2004 Audi A4
Adjust the headlights on 2005 Sebring, Touring Sedan
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall. Also mark where the center of the bulbs would be (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall. For horizontal, aim the hot spot directly at the line you marked for the center of your bulbs
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Aug 10, 2009 | Chrysler Sebring Cars & Trucks
AUDI A4 2003 1.9TDI HOW TO ADJUST THE HEADLIGHT
Please Rate my Response! Thanks!
Jul 13, 2009 | 2003 Audi A4 Cabriolet
Adjusting headlights on a 2005 ford freestar
hello wwhampton,
open the hood, take a close look at your headlights, if it is a headlight assembly, there are two screws with big plastic heads on the back of the assembly, these are the adjusting screws. one for horizontal adjustment and the other one is for vertical adjustment.
if the headlight is a round or square ordinary bulb, the adjusting screws are located near the bulb itself, these are philips screws. one on the top and one on the side.
a suggestion; when adjusting headlights, face the car to a wall about 5 ft away and adjust the headlight.
tnx 4 using fixya.
drcool
Sep 20, 2008 | 2005 Ford Freestar
Quantaray QSX-DigiPro 8500 Tripod Logo
Top Quantaray Photography Experts
R.A. Ellis
R.A. Ellis
Tony Parsons
Tony Parsons
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
