Question about Maxon Radio SL55, SP130, SP140, SP150 Compatible Battery
How can i programme a maxon sl600 v2 radio - Maxon Radio SL55, SP130, SP140, SP150 Compatible Battery
How do i increase the modulation on my maxon mcb-45w
RV 101 SQ RANGE--RV 201 AMC ---RV 202 TX MTR ---- RV401 RX MTR --- Q7 AMC DEFEAT
Sep 19, 2014 | Cinema 4d Maxon MCB 45W CB Radio 120...
How do I change channels on my Maxon 49-sx
  • The "Maxon 49-SX" is a single channel transceiver that only operates on 49 MHz FM. The Maxon "49-FX" and "49-HX" operate on 5 adjustable adjustable frequencies. That radio has no channel/frequency options.
  • Hope this helps.
Nov 18, 2011 | Maxon 49-SX (1 Channel) 2-Way Radio
I have a maxon sl55-u2 frequency radio only channels 1 to 4 work. why is this?
Only 4 channels have been programmed, you will need a programming cable to plug it into a computer and use the maxon software to programme the other channels to whatever frequency you need.
Nov 15, 2009 | Maxon Radio SL55, SP130, SP140, SP150...
Hi i have a maxon Radio i am not sure what model it is as it does not say the model. I was wondering how i would programme the radio so that it would work on a certain frequency
if it is a CB radio, you are stuck on the 27mhz band, and the channels that it comes with. I am not familiar with maxon radio's. Some radio's the PLL chip can be controlled to shift the band the radio works on. This is still limited to the 10-11 meter bands. You can go a band up, and a band down usually.
I have no clue if this radio is capable. So I couldn't tell you how to do it.
I can tell you, that you cannot just pick a frequency and make it work on it.
Oct 24, 2009 | Radio Communications
BATTERY CHARGER HCB-30A CB MAXON
you can get that charger aftermarket at radio shack take the walkie with you to get the right power supply the voltage should be close to where the external power plug goes into the radio.
Mar 13, 2009 | Maxon HCB-30A CB Radio
Replacement Mike for a Maxon SM 4450.sd
Mike the only suggestion I can giv you is to contact Maxon or a local dealer asn ask for replacement parts. The radio shop I work for does not carry maxon or Altronics parts. I only have Motorola and Kenwood commercial radio parts.
Pat N5SLI
Aug 26, 2008 | Maxon 49-HX 2-Way Radio
Maxon sl70
You may want to search this site for a manual.
http://mods.dk/
Jun 20, 2008 | Maxon GMRS50 (16 Channels) 2-Way Radio
Reprogramming a Maxon SP 100G?
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Maxon SP-100G (4 Channels) 2-Way Radio
Maxon Radio SL55, SP130, SP140, SP150 Compatible Battery Logo
713 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
