Question about Fujitsu LifeBook T4215 Tablet PC
Fujistsu T4215 no POST, numlock blinks
On powerup, my Fujitsu Lifebook T4215 screen no longer comes up (no backlight, no image). The blue "power-on" indicator lights up, the hard disk spins up, and the little lcd panel shows that: a) the power is on, b) the DC power is plugged in, c) the battery level is shown, d) and the hard disk activity icon flickers (as you would expect). After a few seconds, the numlock indicator in the little LCD panel begins to blink, which it will do until I power off the machine. Nothing else happens, except the cooling fan will kick up every now & then -- the CPU is warm as usual.
This began right after I (gulp, yes I'm to blame) took it apart in an effort to fix its multibay connector, which had somehow gotten smashed in there. I used this guide on the web: http://simshsia.wordpress.com/2008/07/15/disassembly-of-the-fujitsu-lifebook-t4200-series-tablet-pc/ which made it pretty effortless. The only step I took in addition to the guide was to release the ribbon cable from the multibay connector, remove the two screws that hold the connector in, bend and tweak the connector back into shape (more or less). Then I reassembled the machine in the reverse order. My troubles began then. Before my intervention, the machine worked, but I could not use the DVD or second battery (because the connector was out of whack). Now the battery/DVD will go in (hooray).... but the PC doesn't work. I consider this a degredation ;-)
I have disassembled and reassembled the machine twice more in an attempt to spot connectors that I missed, etc. I even removed the multibay connector to see if I'd possibly shorted something in its pins, but all to no avail.
Help? Thanks - Steve
You need to send it to Memphis, Tn for a factory reset, call the Fujitsu 800 number on there web site and have your serial number handy.
Don't disassemble a Fujitsu!! Ever!
They automatically lockup as a security precaution, aren't you glad you saved some money?
Posted on Feb 09, 2010
Touch screen does not respond
Hello
You need to install drivers of touch screen from disk or update from internet.
Good Luck
Feb 22, 2011 | Fujitsu LifeBook T4215 Tablet PC
Hi. I have a problem with my fujitsu lifebook t4215. When windows is runnning and I change the notebook to tablet config, I cannot get the display/screen automatically rotated. Even when I press the Screen...
Do you have Windows 10? As there may be an issue with screen rotation.
However to check your settings:
  1. Place the tablet into Pad/Tablet mode.
  2. Click the Start menu and select Settings.
  3. Click System.
  4. Click Display.
  5. Scroll down and check the status of Lock rotation of this display .
Jan 05, 2018 | Fujitsu LifeBook T4215 Tablet PC
My fujitsu lifebook t4215 will not connect to the internet. When I check the connection, it says that it is connected, but when I try to bring up Internet pages, it won't bring any up.
So you're connecting with WiFi eh? I take it you've already disconnected and reconnected with no progress?
Next would be to shut it down, and reboot. Try it again.
Are you connecting through a router? You might be "connected" to the router/hub but it may not be actually connected to the internet. Can anything else you have or someone else connect to the internet through the same connection? If so then we know the connection is good, and it's the Lifebook.
Look for "NETWORK AND SHARING CENTER" and see what that looks like. It should show you a graphic of the connection and you may find it as I described above. You need to eliminate or identify your condition at this point.
Good luck!!!
8^)
Jan 04, 2011 | Fujitsu LifeBook T4215 Tablet PC
Bios clock has stopped on Fujitsu T4215 tablet pc. Have tried: 1) updating bios 2) re-installing cmos clock Clock starts again once in Windows (but from static date in bios) and can synchronize clock from...
I thik your CMOS clock (HH:MM:SS ) SS digit not moving forward. If it is then just unplug your CMOS Battery and 5 min later reassemble it ...your problem will be solved.if your BIOS whole setup reset including clock and SSS digit moving forward then replace your CMOS battery...if your not expert to open laptop then take a expart help to open it and run this procedure..
May 14, 2010 | Fujitsu LifeBook T4215 Tablet PC
Some keys not working
Keyboard no good. Just get a new one since you also have an intermittent situation that sooner or later will stop working permanently.
Sep 11, 2017 | Fujitsu LifeBook T4215 Tablet PC
Cannot connect through the internet.
get a network cable and connect it to the pc and then conect gthe other end to your internet router/modem
Mar 21, 2010 | Fujitsu LifeBook T4215 Tablet PC
My lifebook 4215 doesnot display on its screen but can display to an external monitor because the output section of the mb has no small ic like components and a cable jack can I please have a proper...
Call the Fujitsu service 800 number, you may still be under warranty.
It sounds like the inverter has burnt out, take it to a Fujitsu authorized repair shop, your tablet has a security feature that will lock you out if it is opened by an unauthorized repair shop or anyone else for that matter.
They take your tablet security very serious.
Dec 15, 2009 | Fujitsu LifeBook T4215 Tablet PC
Fujitsu LifeBook T4215 Tablet PC Logo
629 people viewed this question
Top Fujitsu Tablets & eReaders Experts
Tony
Mohammad Abumuailek
Mohammad Abumuailek
Computer Links
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
