Question about Euro-Pro 473
Cannot get the bobbin thread to come up with the top thread
Hi there, Im trying to thread my Singer sewing machine. Ive followed all the instructions correctly for threading the machine and bobbin, but for some reason the bobbin thread will not come up with the needle thread when I lower the needle down. Im just learning to sew and I can't get any better if I cant get my machine working. Please help! Thank you.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
1. Make sure the needle is up in the machine all the way.
2. Make sure the flat side of the needle is facing the rear of the machine
3. Only turn the handwheel on the side of the machine towards you, never away from you.
4.Double check your threading of the top of the machine.
5. Also make sure your using the proper needle, your machine takes the most common needle on the market but some look like it and are shorter or longer and wont work properly. Also make sure your not buying needles for a singer serger.
Posted on Oct 07, 2009
4 Suggested Answers
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
  • 17 Answers
SOURCE: Singer 2010 does not make the loop under the plate, to sew.
set up needle properly...
Posted on Dec 25, 2009
I'm trying to load my bobbin on my singer 628 and the bobbin doesn't wind. Any ideas?
Anon, Found links to help with bobbin does not wind, make sure to read the articles in the forums, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://ca.answers.yahoo.com/question/index?qid=20070630202938AAGRwx2
Singer 628 Touch and Sew sewing machine manual smm043 Machines name begins...
Thread Singer 628 Touch and Sew Questions
Apr 05, 2016 | Singer Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
I am having trouble getting the bobbin to function properly during sewing.
It could be the top thread is the problem. Might try removing all the thread. Consult the owner's manual for threading instructions. RAISE the presser foot BEFORE threading the upper thread so the thread will seat properly in the tension disk. Re-thread from the beginning carefully following the instructions--do not miss any spots or thread guides.
If top thread is still creating a mess of loops under the fabric, try tightening the upper tension. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Dec 10, 2015 | Singer 5160 Mechanical Sewing Machine
Bobbin tension
adjust the top thread tension and see if that helps the bobbin tension
stitches.
here is a link for a free manual for the machine
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Feb 27, 2013 | SINGER 7470 Sewing Machine
I just purchased a singer cg-550/500 and after threading the machine and inserting the filled bobbin, I was unable to bring up the bobbin thread with the needle. I followed the instructions carefully but...
if im not mistaken, the bobbin when you place it in the bottom, you have to thread it is as well to the part where the needle comes down and collects and goes back up. please re-look at instructions for placement of bobbin
Mar 05, 2011 | Singer Sewing Machines
Top thread is bunching on the bottom. Ive tried rethreading both threads, changing the needle, adjusting the tension (both up and down) of the top thread. Dont know how to adjust the bobbin tension. Its a...
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Sep 25, 2010 | Sewing Machines
I purchased singer bobbins to use in my singer 5050. I thread the machine and bobbin per manual instructions, but when sewing, the thread severely bunchens and knots up on the bottom side of the item I'm...
Sep 30, 2009 | Singer 5050 Mechanical Sewing Machine
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Need instructions on threading singer pixie sewing machine
i need help too i bought this machine for my 9 year old daughter i thought she was just breaking it bieng so young and inexperienced but my husband and myself have tried also and the same problem accured i tried to follow the instructions but they are so very hard to follow can someone please help me? I keep threading the machine the needle and the threading the bobbin but i get half a stitch and it breaks again. Does
anyone know what im doing wrong?
Apr 24, 2009 | Singer Sewing Machines
Euro-Pro 473 Logo
271 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
