R1800 printer suddenly begins to print too dark. Reinstalled drivers and also connected to a different computer - same problem. Printer test page looks good.
  • 76 Answers
Chec if you have a menu on pc for your printer,so that you can adjust the colour and everything when printing from the pc.
Posted on Oct 08, 2009
HP 6280 Printer. Not printing. Ran diagnostics form HP software. No issues. Printer an computer are communicating. Can run alignment test and Diagnostic Print Page from computer without issue. ...
Well you definitely have a pc problem and not one of the printer. the printer just prints what it is sent and as you can print the alignment page that takes care of the printer.
You have reinstalled the driver but did you remove the old one first? I bet not. You should download the hp printer removal tool. Run it and after a restart then you can install the driver. Personally i would turn off the auto update feature as hp updates really mess things up.
I reckon after the reinstall the printer will be fine.
Jul 23, 2011 | HP Photosmart C6280 Printer
Error message from printer properties : Can not print test page. This operation can not be completed. Take note that printer self-test is working and from printing option cleaning cartrige work perfectly....
You need first to do the following:
Check first a different usb cable ( be the case).
Check that the printer is the default printer or you are not printing to a different printer installed in windows
Do driver setup procedure.
Disconnect printer from usb.
Go to 'installed printers' and remove the printer from windows (right click and delete). If you have documents in printer cue you may need to purge documents in cue.
Restart computer (printer disconnected).
Re-install drivers from disk (printer disconnected).
Only connect printer to usb when required by printer install software or after installing software.
If the above did not work the printer can be faulty, in this case usually it shows some dignostic message, like flashing red light etc.
Check also that is not a windows problem, by installing in on a different computer (get a laptop) and printing a test page.
Regards
Apr 15, 2008 | Office Equipment & Supplies
I have a green OK on but It will not print, will not run a test page and the error message is no help either - what should I do? besides wanting to throw it out the window?
Hello, have you tried a self-test print? which is one initiated at the printer, NOT through the computer.
If you don't know how to perform one, try pasting the link below into your web browser and having a look at the info from the Epso website.
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-R1800/Drivers-Support?target=article&extn=.html&articleId=1365
If you can prove the printer self-test works, then your problem's maybe on the computer side of things; maybe even a driver. If the printer self-test (NOT to be confused with the Windows self-test) DOESN'T work, then take a look at the faq's on the Epson website under 'drivers and support' as below.
Hope this helps!
Kind regards,
nicam49
Dec 22, 2010 | Epson Stylus Photo R1800 InkJet Printer
Printing to bizhub c252 from one computer a problem
s it a shared printer? if it is, install the driver as a local printer
May 27, 2010 | Konica Minolta bizhub C250 All-In-One...
Only test pages print perfectly!!
If when you print a test page it comes out perfectly, that means that the printer works, and the problem is communication between the printer and Mac.
Try the following:
Start testing a different USB cable and a different port.
Unplug Mac, and eventually remove the battery.
Unplug the printer power cable and USB.
Put the mac back toghether and restart it with printer usb not connected.
When mac is on, reinstall printer software driver, with Mac still not connected to printer, using printer disk or download.
Connect printer to Mac when asked by software.
If that still does not work, test the printer on a different computer, even if it is not common, the printer may have a faulty USB port.
Feb 28, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Feb 06, 2009 | HP LaserJet 1320 Printer
Epson stylus photo r1800 photo printing problems
adjust the contrast through the printing preferences in the driver window (control panel, printers and faxes), can you tell me from what program are you printing from? and what kind of file (jpeg,raw,tiff) are you printing?
Sep 05, 2008 | Epson Stylus Photo R1800 InkJet Printer
EPSON 1800 PROBLEMS WITH NEW IMAC
While you may have installed it, the generic driver may be selected. Here are all the steps to get you back up.
To remove any previous Epson printer driver files and get a good working install of the latest download for the Intel Duo Core, do the following:
REMOVE FILES
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
5. Close any open windows.
6. Double click on the MAC HARD DRIVE.
7. Double click on the LIBRARY folder.
8. Double click on the RECEIPTS folder.
9. Delete any "Epson" receipts. Close back to desktop.
10. Open the OS X "Printer Setup Utility".
11. Select the "Printer Setup Utility" menu at the top of your screen and click "Reset Printing System...". Confirm resetting.
12. Close all open windows and restart your computer.
DOWNLOAD
If you have not done so already, use the following steps to obtain the download for the new Intel Duo Core driver:
1. Go to http://support.epson.com
2. Select Printers then Inkjet then your printer model.
3. Under "Drivers and Downloads" select Macintosh.
4. Download only the driver marked for the Intel Duo Core system.
Printer Driver v3.0aAs
Intel-based Macs with OS X (v10.4.4 or later)
epson11769.dmg - 12.4MB - posted on 02/06/06
Installation instructions:
1. Double-click on the "epson11769.dmg" file and follow prompts to create an "epson11769_r1800_printer_driver_30aas" disk image on your desktop.
2. Open the disk image. Double-click the "SPR1800Series 30a" installer icon to begin the installation.
3. Follow prompts to complete installation. Restart Mac once the install is complete.
Do the following to add the printer once the new downloadable Intel Duo Core driver has been downloaded and installed properly:
1. Connect printer.
2. Open Printer Setup Utility.
3. Click ADD.
4. Ensure you are on the Default Browser window.
5. Highlight printer as it appears under Printer Name.
6. For "Print Using" select "Epson Stylus R1800" if this automatically appears on the list. If this does not appear, select OTHER (not "Epson" - which links you to GIMP drivers, which we don't recommend or support). NOTE: if you are using a firewire connection, the printer name may appear as a letter only - ie "E" for "Epson". This is normal.
7. A new window opens where you can Browse to the hard drive location of:
HD > Library > Printers > Epson > Inkjet Printers
(This location contains all the Intel Duo Core Epson driver plugins, be they resident or downloaded.)
8. Highlight/Select the plugin for your printer model in the Inkjet Printers folder, then click OPEN.
9. Use the up/down arrows at the end of "Print Using" again to (re)select the printer's name, which will now appear at the TOP of the "Print Using" list.
10. Click ADD. The new downloaded driver will now be added on the list.
11. If there are other printers on the list, ensure the Epson is made default before testing.
When you are working with a printer model which supports borderless and/or roll paper printing options, you will be able to select these options in the program you are printing from as you set up your print job.
1. Once you have an image or file open, go to File > Page Setup.
2. For "Format For" select the Epson printer name (rather than "Any Printer").
3. Select the appropriate Paper Size. If your printer supports different layout features, each paper size will have several different options. For example, the 4x6 paper size will have an arrow pointing right which offers choices of 4x6 Borderless, 4x6 Standard-Minimize Margins, etc. Pick the paper type plus layout/margin option you want to use here.
4. Click OK on Page Setup. You are now ready to print.
Aug 17, 2008 | Epson Stylus Photo R1800 InkJet Printer
54 people viewed this question
jasbo
jasbo
