Question about Goodman GMS90703BXA Heater
GMP075-3 looks good but shuts off after 10 seconds
I have a 15 year old Goodman GMP075-3. The unit will not remain on more than 10 seconds. The igniter is new, the flame sensor has been cleaned with steel wool, I checked and re-seeded all wire connections for corrosion, the gas is igniting on all 3 burners. I still get one blink on circuit board and it still won't remain on more than 10 seconds.
I turn on the heat on the thermostat and the unit won't stay on. The gas would ignite but the flame would immediately go out. That will continue throughout the day. Sometimes it will heat up the house, but a majority of the time it don't.
Posted on Dec 07, 2009
  • 3,600 Answers
Replace the thermostat control sounds like the control contacts are not holding since you cleaned the bulb and the igniter is working the only other issue is the thermal buld being bad, shut it off heat the bulb for three minuts then quickly turn it back on and see if it stays on longer if it does the bulb is the problem.
Posted on Oct 09, 2009
2 Suggested Answers
milten1
  • 1304 Answers
SOURCE: I have a 15 year old Goodman GMP075-3. The unit
since your getting ignition it sounds like it is shutting off due to airflow
you may want to drop the fan and check the coils above it
and the coils in the pelum with out proer air flow these units shut down at 180 degrees will cycle when cooled again
since your getting ignition your inducer seems to be fine
Posted on Oct 08, 2009
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
Jun 29, 2017 | Goodman GMS90703BXA Heater
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND OUT THE SEER RATING ON THIS MODEL.CAN ANYONE HELP?
Your going to need to know the age of the unit. If its less than 5 years old, its most likely a 13 SEER. If its anything more than 5 years old, its most likely a 10 SEER. If its anything over 10 years old, its most likely an 8 or 6 SEER.
Remember, that a unit will loose an average of 1-2 SEER for every full year of operation. This is just due to age, wear and tear, and usage.
So, if its a 10 SEER unit that is 7 years old, you could say that it is about as efficient as something in the 4-6 SEER range.
Jul 12, 2010 | Goodman CKL36AR36 Air Conditioner
Shuts off after 15 seconds
sounds as if the magnetron has gone bad.this part of the machine is still under a warranty,and you need to call for a service technician to look at it.
do not use the unit until you get someone to look at it and or replace it.
Jan 31, 2010 | Panasonic NN-SN657SMicrowave Oven
I have a 15 year old Goodman GMP075-3. The unit will not remain on more than 10 seconds. The igniter is new, the flame sensor has been cleaned with steel wool, I checked and re-seeded all wire...
Oct 07, 2009 | Goodman GMS90703BXA Heater
Cost to replace carrier 38ckc060
Did your unit work last summer? 10 Years old is very soon unless it is a cheap unit like janitrol or goodman. Most units last min. 15 years and 20 most of the time. Generally speaking any ways. To replace compressor cost maybe 750.00 to 1,000.00 you have a big house looks like. 5 Ton unit. The whole system could be 6000.00 to 8000.00 depending on grade of unit. I would get a second opinion though cause I am wondering if they are just padding their pocket.
Apr 16, 2009 | Carrier 38CKC060 Air Conditioner
Gas furnance won't stay lit.
have a furnace man take a look it sounds like the itermitter control
Feb 05, 2009 | Goodman GMS80904BNA Open Flame Mid-Size...
Hvac
dirty flame sensor
Oct 28, 2008 | Goodman Heating & Cooling
Goodman GMS90703BXA Heater Logo
300 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
