Presario c306usLaptop will power on, display flickers. The laptop
Laptop will power on, display flickers. The laptop has power. When off, the lightning bolt on the front of the laptop will not stay on.
  • mtpmem Oct 07, 2009
    Thanks Will....not...The display flickers and acts like the vertical hold is lost. What can I do about this...should I scrap the laptop or attempt to fix it? Past history- power cord went bad, so battery took a hit. Now I am questioning whether or not it is charging correctly- and if this is related to the display issue
  • 27 Answers
Do you have a question?
wow your laptop has a lightning bolt!!! cool, thanks for the info!
Posted on Oct 07, 2009
Compaq presario cq 56
Unplug the power and remove the battery. Next, hold the power button for about a minute. Than, reattach the power and attempt a boot.
Jul 09, 2013 | Computers & Internet
My LCD screen has been flickering.
Sound like the display panel needs to be replaced
Aug 16, 2012 | Compaq Presario CQ62-215DX Laptop
Compaq Presario CQ56-115DX shows a blank screen on boot, but runs perfect on external display
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 24, 2012 | Compaq Presario CQ56-115DX Laptop
Hi please help me, my compaq presario 1700 flickers then i dont see anything the screen turns into black, but the sound is ok and its not hibernating, and overheating, but sometimes it comes back to normal...
This is most likely an hardware related issue in which case you need to get it checked. To narrow the issue, you can try hooking up your laptop to an external monitor if possible and see if it does the same. If not, then there's probably an issue with the displays internal connectors. You can also try powering your laptop with only the power cable attached and without the battery, then reset all power management settings. If the problem goes away then it's probably a power management issue.
Apr 18, 2011 | HP Compaq Presario 1700T Notebook
Computer won't start up
1. Take out battery
2. plug the laptop in if it starts its your battery if it does not start you might have other issues on the mainboard inside.
Thanks and I hope this information is Very Helpful for you! please rate.
Dec 13, 2009 | Compaq Presario CQ60-220US PC Laptop
The sreen is blinking
you screen may have issue, check the refresh rate in the option:
Desktop/right click/display properties/Setting tab/Advance/Monitor/Chose tickmark "Hide modes that this monitor cannot display"
Now use a lower refresh rate of 60 hrtz)
Power down and restart the laptop.
If the flickering does not go, you may have to visit a computer mart store to check if the backlite / screen inverter board behind the LCD screen is out
Dec 07, 2009 | Compaq Presario CQ60-220US PC Laptop
My compaq presario 1200xl310's monitor remains black. I just purchased a new ac adapter for it. It had been unused for about a month. When I inserted the new adapter and powered it up---no screenlight-up....
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 30, 2009 | Compaq Presario 1200 Notebook
When am switching on the power button of my laptop, it gets on..i think the process is going inside.. But nothing gets displayed on the screen..Please offer me a solution....
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 02, 2009 | Compaq Presario C700T Notebook
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
