Question about HP LaserJet 3050 All-In-One Printer
I cannot scan with my hp3050. i have downloaded full software andscan fix but no help. i get "NOT SETUP ON PC" any ideas?
  • 1 more comment
  • clawson103 Oct 07, 2009
    i have tried your solution and it keeps saying pls make sure the printer is connected to the computer and powered on. it is. i keep clicking ok and it come back with the same pop up
    all connection are good. i downloaded and installed the drivers u suggested and i am still getting the msg "not setup in pc" this problem is not solved
    i cannot scan on my hp3050. i have downloaded version 4 of full software, drivers and scan fix. i have disconnected and reconnected the printer/scanner. i have tried setting every printer as the default. i still get the msg "not setup on pc" please fix thank you
  • 3,741 Answers
After downloading have you --run the setup ---from the downloaded file and installed hp 3050 drivers on your pc. also check the usb connection and also try to give a print command from pc. --if the printer prints ok then its not a driver issue,but if it doesnot print then you will have to run the setup again from downloaded driver files and reinstall the printer and check.
thanks,keep updated and please do rate the solution positively.
Posted on Oct 07, 2009
    Brigadier General:
  • HP Master
  • 3,614 Answers
Go HERE, and try to download the driver from the HP site. Select the OS that your using..
Hope this helps
  • micromaster
    micromaster Oct 07, 2009
    well it seems that there was problem on the connections, did your try removing all connections and connect it again.?
  • micromaster
    the HP3050 was not detected, and it was not installed properly, thats why you get this error, iflook on the printer if it was available and set as default printer
I have hp officejet j4660. when I try to scan, the message appear: no scan options, refer to device documentation to troubleshoot
no scan option means scan setting are not set on the printer. Before you can scan directly from the printer control panel, you must have the printer's Full Feature software package installed on your computer .If you ran the installer and installed everything,then scanner software should be installed on the pc.there must be solution center icon on the computer,as well.Below are the troubleshooting steps for no scan options issue. STEP 1:Download the Scan Diagnostic Utility (click on the link below) http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&lang=en&softwareitem=oj-90927-2 download and run the tool.select the product and click on diagnose.if the printer is not in the box.skip this step. STEP 2: Set up the scan destination list
  • click on the solution center icon on the computer
  • click on settings on the bottom,click on scan settings,click on either scan..to setup or button settings
  • click on scan to setup (front panel list)
  • if this is what you have,then you should transfer all items on the left- hand side to the right-side by clicking on one item and clicking on add until everything is transferred.click on update device.
  • it should look like this.
  • try scanning to pc again
  • you can also try to scan from the pc using the solution center software
  • if the steps above fails,you may need to uninstall and reinstall the software or check this link out for no scan options
  • http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02450835&cc=us&lc=en&dlc=en&product=3692891&tmp_track_link=ot_search#N74
Jun 07, 2011 | Office Equipment & Supplies
When I connect the printer to PC, and press the scan button, the display says that " downloading applicaitons"..No idea what the printer can download?.. When I try to scan from PC , it says...
Try to disconnect the printer from your computer. Restart your computer. Unplug and replug the printer into the power source to reset it. When the printer turns on, reconnect it your computer. Doing this usually fixes minor communication issues. Try to scan again. If problem continues, it could be a firewall issue. Make sure to allow full access to all Lexmark softwares and printer communication processes in the program rules/permissions for your firewall.
May 10, 2011 | Lexmark X5470 All-In-One InkJet Printer
I do have all the setup files of ulead photoshop 3.0 but in virus scan the Setup file is deleted. i want it back yaar.
Hello patiltusharp
Try first a system restore to put your pc back to a date prior to the virus scan .
It this doesn't succeed , download the free version of Recuva to recover deleted data from your HDD : http://download.cnet.com/Recuva/3000-2242_4-10753287.html
Other recovery tools are available here : http://www.geckoandfly.com/3163/crashed-hard-drive-hard-disk-data-recovery-software-tools-and-service/
Good luck !
fanaudi .
Mar 18, 2011 | Ulead Photo Express 3.0 Full Version for...
I was told that I have 253 errors on my computer. I have spoken to e machine to help me fix the problems but they said I would have to reinstall windows thereby removing all the things I have put on the...
If it is errors, they are removable with an anti virus program. Here is a free program you may download that will fix your computer.
http://download.cnet.com/Microsoft-Windows-Defender/3000-8022_4-55082.html?tag=mncol;2
Simply download this and run a quick scan. After that, run a full scan. It may take an hour or two. When it has finished, restart the computer. This should fix your problems :) please give me 4 thumbs up if I helped you!!
Mar 16, 2011 | Computers & Internet
I have a hp3050 laserjet . I can't seem to send
you need to install the full software solution, you can get it from www.hp.com, on newer operating systems, as Windows 7 this option is not available at all
Apr 06, 2010 | HP LaserJet 3050 All-In-One Printer
Scanner not set up
Have to uninstall and reinstall full software solution. First uninstall using the hp program, then use add/remove program uninstall Image zone, extended capabillities and HP update, restart pc and search for scrubber in Hp software it's in utility folder, ccc, doubleclick it to work. then you are ready to reinstall the fully software.
Nov 17, 2008 | HP LaserJet 3050 All-In-One Printer
Fatal error installing HP 3055 all in one
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
Antivirus
Use Ccleaner software to uninstall this antivirus programe.
Jun 25, 2008 | Norton AntiVirus 2004 (0003764823191)
Can't scan
This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
Sep 07, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
57 people viewed this question
Seeker5211
Seeker5211
