Question about Porter Cable Porter-Cable Speed-Bloc Quarter-Sheet Finishing Sander 330
Extreme Vibration in my Porter Cable (Rockwell) 330 Sander
My 330 finishing sander hasn't been used in a few years. When I tried to use it it vibrated so much that I could barely hold on to it. Is there a simple fix or is it shot?
I also have had this problem and I found that if I hold the unit tightly and squeeze the plastic housing the RPM's will stabilize as the unit warms up. Best fix is to replace the rubber isolators that prevent vibrations from the motor from reaching the plastic housing. The isolators have become hard through age or very cold temperatures.
I read somewhere that keeping the sander stored in a warm room can also help because when the rubber is very cold it becomes hard.
Posted on Dec 26, 2009
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have the same issue on my 330 sander but can't figure out how to take off the exterior housing to get to the screws holding the 4 rubber posts on. Can anyone offer some insight?
Posted on Apr 01, 2017
I had the same problem. solution below worked.
WD 40 into the bearings, blow it out w/ compressed air, then bearing lube (spray)
Posted on Jun 02, 2013
  • 3 Answers
Eso esta ocuriendo por un desbalance ,tienes que abrirla y tratar de balancearla , esto regularmente ocurre por la rotura de una goma que se encarga de disimular esta vibracion , solo debes remplasarla.
Posted on Apr 15, 2011
I inherited this sander (Porter-Cable model 330) and the owners manual did not come with it. I am stumped as to how and get the side levers to lift so that i can change the sandpaper (non-stick paper)....
there is a wrench supplied with the tool that you need to insert in the slot on the clamp and push the wrench towards the tool to open the clamp. Now if you follow closely I can direct you to a manual and parts list. Go to "dewaltservicenet.com" and scroll down to the bottom and you will find a porter cable link, click on that and then when you get to the next page click on tools. Scroll down till you find sanders and click on that. Next find finishing sanders and you will find your model sander click on the description and it will again redirect you to another page where you can find the manual. The whole manual is 44 pages long but that includes other languages. The page that you specifically need is page 10. If you have a problem let me know and I will try and help. This is the first time that I have had to take this route to find a manual on their site.
Jul 13, 2011 | Porter Cable Cable 0330 Speed - Bloc...
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
I have a porter cable 7800 sander, when i turned on the sander everything is spinning but the orbital part. i have changed the brushes and other minor things but dont have a clue how to open the orbital...
The best way to sand drywall is to use a pole sander (manually). You can pick them up for about $20.
This particular machine tends to leave grooves in the drywall compound if you are not familiar with how to use it.
If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
Thanks,
Jim
Mar 11, 2010 | Porter Cable 7800 Drywall Sander With Dust...
I HAVE A PORTER CABLE 330 SANDER, IT VIBRATES SO MUCH IT IS UNCOMFOORTABLE TO HOLD. IF I REPLACE THE RUBBER POSTS WILL THIS SOLVE THE PROBLEM? IS IT SOMETHING ELSE?
Not sure if this will work for you, but I had the same problem with my 330, it vibrated so much it felt like I was being electrocuted. I took the four screws holding the pad off and blew compressed air inside the sander to remove all the sawdust. Screwed the pad back on and now it works fine. Mine was only 5 years old with very little use.
Apr 20, 2009 | Air Tools & Compressors
Dry wall sander leaving serious lines in the mud
Shane, it's not the sander that is the problem. This is a difficult machine to use, even for those who have been in the trade for years. The trick is to keep the head moving, and apply vary little pressure. Sorry I didn't find you sooner, but I just found this site 2 weeks ago.I'm sure you have already painted by now but your best bet would be to purchase a manual pole sander. If you have any other drywall questions, or know anyone who does, feel free to ask.
Jim
Apr 02, 2009 | Porter Cable 7800 Drywall Sander With Dust...
Excess vibration
Remove the 4 sander plate screws being carefull not to strip them. Look at the plastic ******** extentions attached/flooting to the houseing and look for broken or bent arms on them ,replace with new ones, this should solve your problem.
Mar 19, 2009 | Porter Cable Cable 0330 Speed - Bloc...
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Wobble in disk
if this is disk type grinder make sure you did not knock the disk out of alignment when it fell off table if so remove and re-align or replace disk seen it before make sure
Nov 24, 2008 | Porter Cable Porter-Cable Variable Speed...
Porter Cable Porter-Cable Speed-Bloc Quarter-Sheet Finishing Sander 330 Logo
1,200 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
