Question about Whirlpool GS460 Gas Kitchen Range
Whirlpool super capacity 465
I have a problem with my oven. When the oven is on for a while{baking a turkey} the oven turns off, the display goes out, and most of the time the display turns back on but the power failure light is on and the clock has to be reset. I took the cover off behind the upright, display board and found a four prong connector that I think is the problem. I can wiggle it around and make display go off and on. My question is how can I tighten up connector if that is the problem.
  • 4 more comments
  • SQue Jan 21, 2008
    Yes, we have the same gas range and it turns off during baking, but the display panel does stay on. We don't know it has turned off until we check our food and clearly see it has not baked - so frustrating! We are thinking of just buying a new gas range.
  • Anonymous Jan 28, 2008
    my whirlpool gas supercapacity 465 oven will turn off while cooking. what is the solution please?
  • SMC1234 Sep 18, 2008
    My whirlpool gas oven switches on, the display says it is heating, then it cools down - it may relight once or twice but eventuallt stops. The display says it is heating but I have to press cancel and then start it over again. It will restart but switch off again after a few minutes. Is it a gas flow problem or an electrical problem?
  • mikejillquin Oct 18, 2008
    i have the same problem the oven will cycle off but will not cycle on untill i restart it
  • Luke Sanna
    Luke Sanna Dec 27, 2008
    We turn the oven on, it ignites, and starts to raise temp, then suddenly quits and the display shows PF. The only solution I have found is to unplug the oven, wait, and then plug back in.
    Today, the ignitor system has failed completely - I do not get any spark for any of the four top burners , or for the oven.
    This is a Whirlpool Super Capacity 465. We just finished roasting the Christmas turkey and the oven is now on the fritz.
  • ouralifamily Jan 01, 2009
    We are having a smiliar problem, the oven begins to heat but then a "E 2 P-1" appears. You can restart it but turning it off but within a minute or two the same error message appears.
Whirlpool super capacity 465- Oven will light and warm up to temp. The ignighter in the oven will then try restart to maintain temp but will not light. Will relight after several attempts. Takes 2 to 3 times longer to bake items. Have plenty of gas pressure.
Posted on Jun 17, 2008
  • John W. Burke Dec 14, 2012
    This is not a solution! It is another question.. waste of time!!!!!!!!!!!
I use the plastic zip ties to hold connecters on cars fairly often I would think this part of the oven is cool enough.
Gene 243
Posted on Dec 25, 2007
I have a Whirlpool Super Capacity 465 and am having issues with the following. Sometimes while baking, the oven turns off and the power to the appliance stays on, sometimes everything shuts off and PF
PF stands for power failure you are loosing incoming power power check the terminal block the control will do goofey thing with loss of voltage rule of thumb no more than a 10% voltage loss 108VAC minuim
Aug 04, 2014 | Whirlpool Ovens
You may have several things going on f1 e4 is a control board issue with the touch panel plug in into the control board disconnect and reconnect if this problem presist will need a control board and touch pad for the oven not staying lit there is a new oven igniter kit 8190618 unfortunately no good diagnostics for this problem good luck
Feb 18, 2014 | Ovens
You may want to put a thermometer in your oven and check the temperature. It sounds like it is too hot and cooks the outside before the inside is even started.
Apr 29, 2013 | Kitchen Ranges
My whirlpool super capacity 465 oven won't turn on.
one of the buttons should have a small icon of a pad lock. press and hold it for 5 seconds. if not turn the breaker off for 5 min then turn back on.
Nov 24, 2012 | Whirlpool 3.2 cu. ft. Plus Washer
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool GS460 Gas Kitchen Range Logo
1,909 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
