Question about Technics SL-1210 Turntable
Hot air balloon does not fire
Hot air balloon is to hot when over volcanoe
  • 69 Answers
You will have to have the balloon re-coilled and resin coated
Posted on Oct 07, 2009
Testimonial: "just as i was told by technics, thanks"
How does a volcano erup
water
Two plates meet up crust is weak volcano appear at these.
Movements in the crusts can also cause pressure to build up .
If hot lava contacts with water . Steam (correction super heated steam) is created under the volcano and builds up pressure until the cool lava to top cannot keep the steam contained and boom.
https://en.wikipedia.org/wiki/Types_of_volcanic_eruptions
The steam can also cause a geyser to occur which is usually less devastating as steam blows out regularly. Happens in Yellowstone Park in USA.
https://en.wikipedia.org/wiki/Old_Faithful
Feb 16, 2017 | Computers & Internet
How much air is contained in a 17 diameter balloon?
It really depends on the shape of the balloon.
If we assume that an air balloon is a sphere, then the volume of the balloon is:
V = (4/3) * Pi * R^3
"R" is the radius of the balloon. The volume might be a bit bigger if it has any bulges on it.
If we assume the balloon is a cylinder, then the volume is
V = L * Pi * R^2
"L" is the length and "R" is the radius of a circular cross-section.
Feb 19, 2015 | Computers & Internet
How do volcano work and explode?
The purpose of the project is for your group to do the research, sift through the documents, select material, write and rewrite. All we can help you with is to give you some links you could explore.
Volcano Wikipedia the free encyclopedia
Volcanoes 101
Annenberg Learner Interactives Volcanoes Introduction
Sep 12, 2014 | The Learning Company ClueFinders 5th Grade...
Angle depression
Hi find answer by skeeter here
http://mathhelpforum.com/trigonometry/99703-trigonometry-help-totally-stuck.html
Nov 20, 2017 | Math
Not enough air bubbles coming out of my volcano
Clean air release. holes .pumps do get weaker when old
Feb 08, 2013 | TOP FIN Volcano Bubbler Aquarium...
R350 2006 air balloon problems in the rear . it gos down all the time even the air balloon are brend new
R350 2006 air balloon problems in the rear . it gos down all the time even the air balloon are brend new MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
Jan 09, 2013 | Suspension & Steering for Mercedes-Benz...
Hi, my son has just kicked his balloon into the return air vent and been taken into the pipe of our ducted heating system.
no louver cover over the vent? If you can see the balloon spray peroxide on it to deflate it and fish the balloon out with an electricians wire feeder
Jul 16, 2011 | Heating & Cooling
What is pilot light?
A pilot light is the Flame that runs constantly, when any Gas appliance is operated, it is there always burning, very small flame, that is used to "Ignite" the main burners in the device.
Feb 21, 2010 | 3d Rose Hot Air Balloons - Hot Air Balloon...
Frost occuring inside the frig on the top around mechanism
J,
Frost is indicative of an air leak (which means that the door seal is messed up).
Pardon me while I jump off into a thermodynamic primer here...
All of the "cold" is made in the freezer compartment. There's a fan in there that circulates this chilled air around... Only a portion of the chilled air is directed (ducted) to the fridge (beer) section.
Here's where the nifty thermodynamic whiz-bangs happen... Hot air balloons float why? Because they're lighter than the air surrounding it! (And a hot air balloon is "attracted" [like a magnet] to the coldest spot in the atmosphere) Ya know why? Because nature abhors a vacuum. Nature is always in a struggle to balance itself. So the cold air above actually pulls the balloon into the air and tries to stabilize its' temperature and equalize it with the surrounding environment (at that equalization moment, you wouldn't wanna be in the basket... know what I mean? Crash, Boom, Bang)
By "refrigerating", we are, by nature's rules, "breaking the law". We're actually pulling (removing) heat (calories) out of the food and transferring that heat to the outside of the fridge. Nifty, huh? Instead of applying "cold", we actually are removing heat!
Ok, OK... back to your issue. Frost is only water vapor that is suspended in air... When this warm air comes in contact with a "cold" surface it condenses OUT of the warm air and clings to the colder surface... think of a glass of iced tea on the patio, you know how the glass "sweats"? Imagine that your glass of tea is 22 degrees below zero Fahrenheit and now imagine what would happen to all the warm moisture laden air surrounding it. Yep, you're right... It would sweat out on the coldest surface and then quickly freeze/frost.
Now back to the balloon thing... (and nature). .. Cold air is "heavier" (more dense) than hot air, right? So if there's a leak (think of air as a fluid) of cold air [which flows toward the floor] there MUST be a replacement, right? (The whole "nature abhoring a vacuum" thing) Cold air flows out and warm (moisture laden) air fills the vacuum. Where does this warm air go?
Yep! It goes where the balloon goes! To the coldest spot it can find! (You're good at this!) Where's the coldest spot in the fridge, you ask? Well? It's at the top left, inside the cabinet. In the very back, you'll see the damper. It's used to adjust the amount of cold air flowing into the fridge compartment. When warm air hits this (the coldest part of the fridge) it immediately condenses and frosts over. This frost builds up a wall. This wall stops air from circulating. When air stops getting to the fridge, your eggs spoil, your mayonaisse stinks and your beer isn't worth squat.
Now for the "WHY" of it all... Could be several things allowing warm air into the fridge.
First thing to check is the rubber door gasket. Make sure it's seating properly all the way around the door. If it's not, the door may be warped... try to warp it back into shape. You have to do this physically.
Second, use some "Vaseline" and rub a thin layer of it onto the door gasket (the part that seals against the frame). Not only will this help make a good air-tight seal, it'll also help keep the door gasket supple and intact for the life of the refrigerator.
Take this knowledge and prosper... (only AFTER you've rated this soltion as "FixYa", though)
SG
Apr 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Technics SL-1210 Turntable Logo
81 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
