Question about HP Compaq nx6110 PC Laptop
Hp nx6110 laptop keeps hanging but works well when pressed on top of touch pad or hard drive.
    Problem Solver:
  • 7 Answers
Only if you have knowledge on hardware Laptops you understand. The procedure go as follow:
Unscrew the motherboard completely.
Identify the North-Bridge BGA IC (BGA= ball grid arrays) under the mouse region.
Get an SMD Rework Station.
Suspend the board on a surface which cannot be affected by heat and held firmly whereby under the North-Bridge BGA IC is opened.
Use your SMD Rework Station to generate heat  evenly beneath the region North Bridge IC and press gently without being bridged.
Mind you 90% risk is involve.
Posted on Jun 27, 2010
2 Suggested Answers
  • 256 Answers
SOURCE: laptop keeps hanging
Overheating is one of the frequent causes of freezing and other errors in your HP Laptops. So, if your laptops keeps freezing then the first and the most important thing that you would have to check is whether your fan is working or not. If your fan is not working then you would have to buy a cooler pad for your HP laptop. The cooler pad which sits under your laptop would prevent it from getting overheated.
Posted on Sep 21, 2011
I have hp nc6220, if often hangs and is always unpredictable, but when i press its touchpad from downward and keep it pressed it works, when i release that it hangs again
I had this problem (hanging on the screen with F10 = ROM based setup) for a while on my HP nc6220 laptop. Was taking several attempts to boot. Replaced the hard drive. Ran virus and malware detection, all clean. Stumbled on to the posting where someone wrote about applying pressure by the touch pad seemed to help. It did. Then the problem gradually got worse. Thought maybe there was something loose. Downloaded the disassembly procedure from hp.com. I found the 2 ground contacts under the touch pad had oxidation on them. Cleaned them with a pencil eraser. Reassembled the laptop and have not hung once. Everything runs faster as well. This is not for the novice, but someone with a little experience should be able to get through the process. Hope this helps someone.
Dec 24, 2010 | HP Compaq nc6220 Notebook
My laptop usually hang during booting, until i press down the side of the processor before it continue
This problem from the chipset .. this is a big chip ic u need to remove reball and fix it again... u can if it under the mouse pad.. when u open laptop ..Thanks
Sep 08, 2010 | HP Compaq nx6110 PC Laptop
HP COMPAQ NX6110 LAPTOP HANGS WHEN BOOTING, BUT WHEN PRESSED AROUND THE MOUSE PAD OR HARD DISK AREA IT WORKS , BUT HANGS AGAIN LATER
It seems that the hard drive or the memory module is not seated properly and hence after pressing on the area below keyboard it gets released.
You can try following things.
Remove and reseat the Hard drive.
And remove and reseat the Memory.
Try to power on the laptop again.
If is getting hang again then you may need to do the HDD self test and memory test built into BIOS.
May 26, 2010 | HP Compaq nx6110 PC Laptop
Mouse pad's not working
HAVE YOU REDONE THE DRIVERS IF PRESS ON THE PANEL AT TOP OF PAD DOSE WORK IF IT IS A BORD PROB SAME AS HP NX6110
Jan 31, 2010 | HP Pavilion dv4000 Notebook
My compaq nx6110 keeps on hunging randomly ,but when you press somewere near the touch pad it becomes normal
its due to two reason
1,hard disk failure first stage
2,virus
for virus you have to do following steps
1,download spybot from the internet
2,install and scan
3,fix selected problems
Nov 01, 2009 | HP Compaq nx6110 PC Laptop
hmmm..that sounds like a motherboard problem about to happen. you have warranty coverage on this unit? also, you may wish to turn over the computer, remove battery, get static off your hands, then remove and reseat the memory cards underneath(most likely behind a small panel with a small phillips head screw).
Oct 07, 2009 | HP Compaq nx6110 PC Laptop
Laptop keeps hanging
TRY TO BACK THE OLD ONE IF IT IS OK THE NEW ONE ARE NOT COMPATIBLE
Aug 18, 2009 | HP Compaq nx6110 PC Laptop
Hangs wihle running and starts if pressed on top
check the hard drive connection. it is probably loosed or the connector is bad or you are experiencing a bad sector on your hard drive.
Jul 15, 2009 | HP Compaq nx6110 PC Laptop
My laptop compacq nx6110 hang i hv to press the motherboard
this problem is hardware related, this problem caused by the chipset "intel 82801 fbm" . if you have an electronics experience,
remove the mother board,
find the chipset intel 82801 fbm
reflow the chipsett by "bga rework station" or "hot air blower"
then refix and check the system
Jul 04, 2009 | HP Compaq nx6110 PC Laptop
Computer freezes...but not in the normal manner
The intel chip that is under the touch pad is the culprit. If you open the laptop by removing the keyboard, you will notice the chip just under the cover. i have tried putting pressure on it with an eraser and got some results. Mackay Rigava
Oct 12, 2007 | Compaq NX6110 TFT XGA Notebook
HP Compaq nx6110 PC Laptop Logo
324 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
