Question about Whirlpool Dryers
Dryer keeps stoping and giving E1 code - Whirlpool Dryers
  • reneng Oct 07, 2009
    Will check this and get back
    Thanks
  • Whirlpool Master
  • 19,396 Answers
Hi.
On whirlpool dryers E1 means that the thermistor located on top of the blower housing has blown (open circuit). The thermistor can be reached removing the bottom quarter panel, which is located on front side, below the door, near to the bottom.
Enter the model number here to get parts and diagram for your appliance.
Regards.
Posted on Oct 07, 2009
Shortly after starting a load in the dryer, the dryer stops, beeps and the lighted code says E1. The grid on back wall of dryer is very hot. I am unable to find my instruction booklet. This keeps...
The E1 error code means that the electronic thermostat is the problem. With what your describing as far as it being very hot and the E1 code,i would suspect one of 2 things;
1) the thermister is bad and needs to be replaced
2) thier is a blocked/restricted vent and or excessive lint built up in the blower housing causing the heat to be retained in the dryer instead of being vented out and across the thermister where its getting a false reading and throwing up the E1 error code
GENE
Sep 12, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The dryer keep saying E1
Hi, Error E1 indicates a thermistor failure. The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F. When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
Normal thermistor resistance values: 60 degrees F. - 15.3K ohms. 70 degrees F. - 11.9K ohms. 80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Code E1
E1 or E2 Thermistor Failure
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
E1 code on kenmore front load dryer
Hello there
I have written a list of codes that should cover your problem nd give you some idea what to check ok
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
80 degrees F. - 9.2K ohms. E3 Touchpad or Software mismatch Flashes when there is a touchpad or software
Dec 16, 2009 | Kenmore Dryers
I'm getting an E1 signal from dryer...What is the
This usually works to unlock the E1 code
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal buttonfor 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control
Locked light is on, the dryer can be stopped by
pressing the Pause/Cancel button, but cannot
be restarted until the control is unlocked.
If this worked for you don't forget to give me a ranking. Thank you!
May 06, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
My whirlpool gas dryer keeps coming up with E1 error code after drying for about 50 min, model ggw9200lwo. Any solutions to what the probelm might be?
The E1 code means there is an open thermistor. This thermistor is located on top of the blower housing. Access it by removing the bottom panel on the front of the dryer. This device is not repairable, so unless it's just a loose connection or the device is not firmly mounted, it will need to be replaced.
Unplug the dryer before you work on it!
Mar 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Aug 05, 2008 | Dryers
Error Code E1
Usually when the thermistor is repaired the high limit is replaced, I dont recall the E 2 except a manual is under the console
Jun 01, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Dryers Logo
21 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
