Question about Xerox Office Equipment & Supplies
Xerox WorkCentre 5230A email print problem.
Our office printer is a Xerox WorkCentre 5230A PCL6. When I print an email (Outlook 2007) the header is ok but content is reduced with 80mm margin to the left.
If I select another printer there is no problem.
I changed my default printer to a machine which works properly
Posted on Oct 08, 2009
What is error 027-502?
Appears to be error message related to networking.
26171215-uilodj0wn3aoics0ffhdkown-5-0.png see page 412 of 454 in the attached manual Xerox WorkCentre 5230A System Administration Manual Page 412
Apr 21, 2016 | Xerox WorkCentre 5325 5330 5335 Black...
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
XEROX WORKCENTRE 7328 IS RUNNING SLOW WHILE PRINTING PDFs
Are you printing to the printer using the Xerox Global Print Driver PCL6? If so, this will be the cause of your problem. Earlier versions of the driver werent as bad when processing PDF documents. I would suggest that you download the Workcentre 7328 PCL6 driver and try that - the problem should clear.
Cheers
Jon.
Dec 17, 2010 | Xerox WorkCentre 7328 Multifunction laser...
I have Xerox WorkCentre 5230A when i am scanning it is give me this error code 018-591
According to the manual, 018-591 means:
"The number of suffixes attached to folder or file names exceeded the limit.
Change the names of existing folders or files, or move the folders or files into
another folder."
good luck
Nov 29, 2010 | Xerox WorkCentre M118 Black and White...
Having problems printing 11 x 17 calendar on Xerox 7335. Print monthly view of MS Outlook 2007 calendar from MS Calendar Printing Assistant and the calendar does not fit page. It shrinks the margins of the...
Try using the Postscript Driver. Once it is installed, you should be able to open the Properties > Advanced > Printing Defaults > Advanced > Image Options > Margins and set it to None.
Nov 18, 2009 | Xerox WorkCentre PRO 128 Copier
Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Jul 01, 2009 | Xerox WorkCentre Pro 423 Copier
Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
Dec 07, 2008 | Xerox WorkCentre M15i Laser Printer
Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Sep 08, 2008 | Office Equipment & Supplies
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
177 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
