Question about Canon PowerShot A590 IS Digital Camera
My camera will not turn on at all. e
My camera will not turn on at all. I was in the process of transfer picture to my pc when the amera turned off. I replaced the old batteries with new thinking that was the issue but the camera has not come on since
t00nz
  • 4738 Answers
SOURCE: Power Shot A560
Really the simplest, easiest, and fastest way to download would be with a USB card reader. Simply pull the memory card out of your camera, insert it in the reader, then your computer will recognize it as a hard drive. Simply drag and drop all the pictures from the card to your computer. You should also experience much faster download speed with a reader than from the camera. And card readers are very inexpensive these days:
http://www.amazon.com/s/ref=sr_st?keywords=memory+card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Amemory+card+reader&sort=price
Posted on Feb 18, 2008
t00nz
  • 4738 Answers
SOURCE: No display at all. But able to take pictures with Canon A75
Sounds like you might have accidentally turned the display off. Turn on the camera and press the DISP button once on the back of your camera.
Posted on Mar 19, 2008
  • 65 Answers
SOURCE: Error 99! Wont' take picture, the message states
Go to the www.canon.com website and find out what Error 99 means. ted10
Posted on Apr 20, 2009
BillB-SA
  • 2761 Answers
SOURCE: New batteries but still no power on.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
Posted on Oct 20, 2009
Tri3mast
  • 747 Answers
SOURCE: I have a Canon G5
Thank you for such a detailed description, wishing others would take your lead. To the problem camera designated batteries (other then AA rechargeable) have always been a bit of a sore spot for me because the user is compelled to purchase a specific battery. As much as I prefer the name brand accessories for the camera there come a point where you just gotta venture forth with third party accessories. There is nothing wrong with using an "off" brand in fact what I've found is that is some cases they are a better battery. Again back to the problem. I grasping thoughts on how to word this but, here goes. As much as the manufactures would like you to believe that these batteries do not form a memory they do. Also the battery can trick you into thinking it's fully charged when in fact even though the charge light is saying completed it's only got about 1/3 charge. I've worked with Canon's BP 511 and now the "new" BP 511A for many years The BP511A or equivalent is the better battery. What needs to be done is to drain those batteries down until they stop, let it cool don't take it from the camera to the charger. Time the battery when you put it on the charger, meaning not to the second but what you would "normally" do is plug the battery into the charger and leave it right. Well what's possibly happening is that within ten minute the ready light is coming on, (something stupid going on in the battery) So check the battery stat of charge after say 15 minutes and if it says it ready (drum roll please) remove the battery unplug the charger for a few seconds and place the battery charger back onto the wall outlet and plug the battery back into the charger and look at your watch again. I've had to do this as much as three times until the thing would get the idea it was to take a charge "normally" about 2 hours will bring it back up. There is no device I've found to completely drain one of these batteries so over a period of time in your case one year the batteries begin this fit. I've since replaced the BP511 for the better BP511A's or equivalent. I'm not pointing a finger because myself and staff do the same thing and pull the battery before going to a shoot if it's showing partial discharge and the thing gets put onto charge and we start this cycle all over again. Be careful of the charger as well meaning don't just disconnect the battery and put it back on charge when it's going the cycle thing disconnect the charger from its power source as well because it holds a memory for a few seconds and will just shut off in a few moments if you don't.
Long story but I've been doing this now for 9 years since the dawn of Canon's 30D Cheers
Posted on Jan 16, 2011
Dmc ls80 transfer
Most cameras don't have enough internal memory to take more than 1 or 2 pictures internally. Picture transfer is normally accomplished via usb cord. The process begins when you plug in your usb and power on the camera. You have to navigate between internal memory and SD card in windows explorer.
Jul 22, 2014 | Panasonic Lumix DMC-LS80 Digital Camera
Why can't import my pictures into the computer?
Have you downloaded the Kodak Easyshare software? It will be easier to transfer picture from the camera to the computer also easyshare software has feature to enchance picture download not to mention that you can send picture thru email using the esayshare software. To download the software visit www.kodak.com/go/easysharesw.
Transferring pictures/videos with the USB cable
Turn off the camera.
2 Plug the labeled end of the USB cable into the USB port on your computer.
3 Plug the other end of the USB cable into the USB port on the camera.
4 Turn on the camera.
Note: EasyShare software opens on your computer. The software prompts you through the transfer process.
If still having issue importing picture from the camera to the computer call Kodak support line at 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z730 Digital Camera
Question after I download my pictures to my pc. can I redownload the pictures back to the canon power shot a520?
As a part of the download process, most cameras and transfer applications ask you if you want to delete the images off of your camera once they've successfully transferred to your PC. Check the preference setting of the application you're using to transfer the images to your PC. Best way to check is to transfer images to your PC, disconnect the transfer cable and see if the images are still on your camera.
Nov 17, 2009 | Canon PowerShot A75 Digital Camera
Kodak c813 camera lost picture - transfer from camera to pc
There is a limit to how much data can be transferred at the same time.
I suggest to transferre in intervals.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak Easyshare C813 Digital Camera
Trouble viewing pictures transfered to the memory card
The process only works one way...you can download pictures taken on your camera to your computer but you cannot download pictures from your computer to the card and play them back on your camera.
Oct 06, 2009 | Canon PowerShot SD1200 IS / Digital IXUS...
I am having a problem tranferring pictures from my Z1485 IS camera which is brand new. When I connect the transfer cable and then turn on camera to transfer, the camera turns on as indicated by the on...
there are two things,, you are either want to transfer the digital camera pictures from you camera, and other is you want to connect you camera to pc and want to shoot live,
for transfering,, generally with common drivers ,, once you connect to pc, you will get a drive letter in matter of seconds of time in your pc,, go to windows explorer and view you can find them..
Oct 03, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Nikon P80 Transfer problem. The Nikon Transfer program either stalls and will not process. I have to turn off and unplug the camera and start the process again. After several attempts and a long period of...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Jul 06, 2009 | Nikon COOLPIX L3 Digital Camera
Downloadind pictures
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. This is normal processing. The camera screen should shut off as the computer is now taking over to transfer the data from the memory card to the computer.
Jan 05, 2009 | Olympus FE-220 Digital Camera
Can't access pictures or turn on camera
Hello, if the batteries where not fully charged when you where copying pictures to PC, the camera may have corrupted the pictures on the xD card. That is why the camera is showig a grey picture and turning off, it can't work without a valid picture card. A vey good way to restore the pictures on the card is to buy a card reader (they are unexpensive) that can handle xD cards and use a picture restore software.
For the restoration proccess, read the following page:
http://techblissonline.com/photo-recovery-deleted-pictures-corrupted-images/
Maybe you don't need to buy a card reader if your camera is recognized as a disk drive by the computer but I strongly recommend a card reader for future picture downloading to PC.
After recovering your pictures, you have to format your card in order to use it again in camera.
Nov 21, 2008 | Fuji FinePix F470 Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
