Question about Intermatic & Indoor/Outdoor Rain Tight Timer
T104-50 clock not working
I have a T104-50 which switches a swimming pool pump on once a day. We had a power cut recently and since then the Clock is not working. There's definitely power getting to the timer as the manual switch will operate the pump - is it faulty, is there anything I can do to verify one way or another?
  • 1,343 Answers
YOU CAN LOOK THREW THE LITTLE WINDOW TO SEE THE GEARS TURNING ON THE CLOCK .. IF NOT .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX ON EBAY
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ. .. VOTE PLEASE THANKS... JAY
Posted on Jun 02, 2010
My pool heater will not turn on with clk code
clk is clock mode if no system control put in standard mode if using control unit put in remote
Jul 28, 2014 | Raypak Rp2100 Pr406aen 406k Natural Gas...
Have a pantera p24 sand filter from wicor and the lable has gone from the control lever. I need to know what function is in each position.. filter, rinse, backwash etc.
don't know if you got it fixed or not but can give you mine....if your looking at it from the top it goes like this....in the twelve o'clock position nothing,1 o'clock is recirculate then 3 o'clock is backwash then 5 o'clock is close then 6 o' clock winterise then 7 o'clock is waste then 9 o'clock is filter then the 10 or 11 o'clock is rince. hope that helps..
Jul 15, 2011 | Wicor Industries Master Plumber Geyser...
Need wiring schematic for a 115 volt install
THERE ARE THREE SCREWS 1 AT ONE O-CLOCK(GOUND) THE OTHER 2 AT THREE O-CLOCK.ARE THE LINES(POWER). THE CAN GO ETHER WAY ! YOU WILL NEED TO SET THE SWITCH OR WIRES TO 115 V POSITIONmotorwizj_0.jpg LOOK ON THE MOTOR LABEL IT TELLS YOU HOW TO SET IT UP . HOPE THIS WAS OF HELP. IF IT WAS CLICK ON THE YES HELPFUL BUTTON .. THNX... JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 13, 2011 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Mechanical Pool Pump timer. The clock is not working. I can turn my pump on manually but when I set the time the clock remains at the same time and does not move.
The timer wiring provides power for the clock itself. If it is incorrectly wired or if the clock is not working, the pump will not turn on.
Gary
Mar 01, 2011 | Intermatic T104 24h 208-277v Mechanical...
My pool guy had turned off the remote feature of the gas pool water heater. I have held the 3 buttons and now it says press clock ( clk) and the top right flashes service. How do I get back into remote...
The clock indicator means the firemans switch is open. If you are running the heater remotely and thru a time clock the time clock is still off. Turn all the equipment on including the timer and you should be able to put the heater into remote mode.
If you still have trouble, please comment with your actual model and serial number from inside the heater.
John
Nov 05, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Dayton mfg time switch for pool pump no info on the switch, model no or anything other than mfg. 240 V to a GFI to a throw switsh to the pump motor.Switch is 5 pole (A,1,2,3,4) How do I wire this properly...
I don't know about your GFI, but it probally wires off one of the hot leads.
As for the others two come in (line) and two go out (load) The two that come in will hook to the two leads that have seperate leads running to the clock motor as this needs power all the time. These are probally small wires that come off the main terminals and go behind the clock wich is where you will find the clock motor.
The leads going to the pool motor will hook to the other two terminals.
Your last terminal is probally a ground.
If you take the gut to a pool store they can probally match it. Home Depot or the like will have to many other types to match.
The new one will have instructions and a sticker for your door on the clock for future reference.
Hope this helps, good luck.
Jul 05, 2010 | Pool & Spa
Swimming pool time clock face doesn't move
The timer has internal switches that you connect the input and output to . That is the NO, C , NC set of contacts. It also has a set of terminals for the clock, usually the first terminals on the left. Before connecting a feed to the clock, confirm the voltage rating for the timer. the clock voltage may be different than the contact voltage.
May 05, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Clock does not turn on
make sure the small white wires coming from the clock itself are installed on the "line" side of the terminals, those power the clock. If not, the switch will power the pump but the clock will not run.
Sep 15, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Once T101 Timer Shuts Off will not turn back on
you have the hot and load reversed. the power source should connect to terminal 1. the wire going on to the pool pump should be hooked to terminal 2.
the clock motor is powered off terminal 1 and A is the neutral.
what u have done is hooked the power source to #2 and the load to #1, simply switch them and everything should be fine, here is a link to the wiring diagram for the timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
Aug 22, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Clock not working
the white wires that come from the clock need to be connected to both of the "line" terminals. If you have them connected to the "load" side, it will cut power to the clock once it turns off and it won't turn on again... hope this helps...
Jul 14, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
241 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
