Question about HTC P3300 Smartphone
HTC P3300. WM 6. Speaker won't turn off during calls
HTC P3300. WM 6. Has been hard reset. No additional programs on it. During calls the speaker remains on very loud and can't be selected off. (The mic also was very poor before the reset but now OK)
Hi
I have a similar problem. Some time my phone works fine and some time the speaker is on and can't switch it off.. this is due to the charging pin, loose connection.. you need to handle carefully while detaching your phone from data cable or the charging wire.
Posted on Nov 03, 2009
I hear echo
Are you or the other person using the speaker phone function? Does this happen during conference (3 way) calling? If you're using the speaker phone function, especially during a conference call, you're likely to hear an echo. I've had this very same issue with a different phone and the only solution I found was not to use speaker phone.
Good Luck!
Jan 05, 2013 | HTC EVO 4G Smartphone
How to get the speaker phone
Hi i've inserted a link to the manual below:
Turning the speaker phone on or off during a call On the screen, to toggle between turning the speakerphone on or off. The speaker phone icon appears in the status bar when the speakerphone is on. To avoid damage to your hearing, do not hold your phone against your ear when the speakerphone is turned on PAGE 48
MANUAL: http://member.america.htc.com/download/Web_materials/Manual/HTC_Aria_ATT/100810_Aria_AT&T_English_UM.pdf
Jun 27, 2011 | HTC Aria Cell Phone
I have forgotten my password for htc p3300 how to unlock it
you need a hard reset. your all user data will be lost.
Hard reset:
1. power off phone
2. hold 2 soft keys (minus sign keys)
3. while 2 soft keys holding reset (reset hole)
4. press Green (call button) when you see instructions on display to do so.
Apr 29, 2010 | HTC P3300 Smartphone
Speaker phone is always on in out going and incoming calls.
head phone socket problem. contact good technician
Sep 21, 2009 | HTC P3300 Smartphone
HTC P3300 Ringtone & WMP not working
sounds like a hardware problem.
try opening the phone up and having a look at the speaker connection.
maybe get a new speaker for it if problem persists.
Jul 20, 2009 | HTC P3300 Smartphone
During a call,phone will switch automatically to hold or...
try resetting the device
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
otherwise go and update ur pda software with latest at www.htc.com i mean ROM and see if it helps
Jan 31, 2009 | HTC Touch P3450 Smartphone
The speaker does not work properly.
Try a hard reset, press power, volume down, and enter/ok/center button, all 3 at the same time, and while pressing those down, press the reset button in the back down. Once it reboots, you can let go of the reset button, but keep holding down the other 3 until you get a message asking you to revert to manufacturers settings.
This will erase all data and settings, so make sure you backup your files (and use ActiveSync to sync contacts to outlook, to make a backup of contacts).
If this doesn't work either, then if you have the warranty, send it back to HTC to get it looked at.
Jan 09, 2009 | HTC Touch Diamond Smartphone
Hard reset
Occasionally, you may need to reset your device. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when your device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost.
You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings — the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on your device will be lost. Only Windows Mobile software and other pre-installed programs will remain.
To perform a soft reset
Use the stylus to press the RESET button found on the lower left side of your device. Your device restarts and displays the Today screen.
To perform a hard reset
  1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the lower left side of your device.
  2. Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: “Press Send to restore manufacturer default, or press other keys to cancel.“
  3. Press on your device. Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have been backed up before a hard reset is performed.
Oct 29, 2008 | HTC P3300 Smartphone
Touch screen do not respond
could you explain in detail what s happening with your phone??
u said that ur phone cannot be unlocked...but then u say that it happens typically during nights...do u mind elaborating?
May 10, 2008 | HTC P3300 Smartphone
HTC P3300 Smartphone Logo
187 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
