Question about Marantz DV6001 DVD Player
Not recognize the disc - Marantz DV6001 DVD Player
  • 405 Answers
You will have to replace DVD mechanism, unit should be still under warranty (36 month). right?
Posted on Nov 09, 2009
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
No Discs
Does this happen with all discs?
Jan 07, 2008 | Lite On LVW-5005 DVD Recorder
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
Does the unit recognize 80 minute discs?
Any desk CD recorder will only recognize discs labeled "Audio Disc".
That means you cannot use CD-R or CD-RW discs, that are basically data discs. No matter duration, if your 80 minute disc is CD-R or CD-RW, your unit will not recognize it. Good Luck.
Flavio/BRAZIL
Jul 25, 2010 | Philips CDR778 2-Disc CD Recorder
Laptop drive not reading Blu-rays
Please install the a trial version of Power dvd blue ray player from the below link and check if it works for all the disc.
http://download.cnet.com/CyberLink-PowerDVD/3000-7970_4-10352449.html
I think it should work.
Jun 04, 2010 | HP Computers & Internet
My Initial DVD player does not recognize discs at all
replace the optic lens and the spindle motor or if you do not have time try to purchase a optic assembly so that its easily to replaced.you have to purchase is the same model as your unit brand.
Sep 24, 2009 | Televison & Video
Disc drive stopped recognizing discs
This is fairly common, it means the actual DVD drive has failed. You will need to call Nintendo. There is a good chance it is still under warranty and they will fix it for free. Their number is 1-800-255-3700
Aug 08, 2009 | Nintendo Wii Console
Everio dvd burner will not accept discs
try using a disc cleaner on the unit and then try it
Jul 31, 2009 | JVC Everio Share Station DVD Burner Burner
Can't record anything....dvr won't recognize blank
Not sure, but could be as simple as switching to a dvd-rw disc. Not all recorders recognize all formats.
Mar 16, 2009 | Televison & Video
Won't recognize blank DVD+R disc
Try the next disc in the stack, and see if it will recognize the next one. If not, the problem is most likely the recording speed of the +R disc. Before you go changing disc types, however, I would also check the Record Mode you have set for the dub - if the REC Mode is set for XP, try changing the mode to SP and see if you have any luck. If it still won't work, try one of the tested +R discs:
SONY (2.4x, 4x, 8x, 16x)
TDK (4x)
Mitsubishi (4x, 8x)
Ricoh (2x, 4x, 8x)
-Tha Mp3 Doctor
Feb 14, 2009 | Philips DVDR3320 DVD Recorder/VCR
Marantz DV6001 DVD Player Logo
83 people viewed this question
Top Marantz Televison & Video Experts
 Grubhead
Grubhead
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
