Question about Rollei DP6200 Digital Camera
Could you kindly advise me to where I can get a conversion adaptor for my Rollei DP6200 camera Thank you
How do I get the protected card mode off?
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 08, 2012 | Rollei DP6200 Digital Camera
My camera lens is stuck. It won't go down automatically when i turn it off.. i have tried charging it already but still the lense is stuck
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Rollei service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Mar 04, 2011 | Rollei DP6200 Digital Camera
I HAVE LOOKED EVERYWHERE FOR A BATTERY FOR MY ADVENT DIGITAL CAMERA (ADV 1182E) BUT NO LUCK. CAN ANYONE TELL ME IF ANOTHER BATTERY CAN BE USED??.
Three years ago a guest on FixYa wrote this:
quote
Here's a list of cameras that use the same battery.
ADVENT:
ADV1172E
BENQ: BENQ:
DC C500, DC E43, DC E53, DC E63+, DC E720 DC C500, DC E43, E53 DC, DC E63 +, DC E720
KONICA MINOLTA: KONICA MINOLTA:
DiMAGE E40, DiMAGE E50 DiMAGE E40, E50 DiMAGE
PREMIER: PREMIER:
DS-4331, DS-4346, DS-5330, DS-5341, DS-6330, SL-6, SL-63 DS-4331, the DS-4346, the DS-5330, the DS-5341, the DS-6330, SL-6, SL-63
ROLLEI: ROLLEI:
Prego DP4200, Prego DP5200, Prego DP6200 Prego DP4200, Prego DP5200, Prego DP6200
End quote
Nov 27, 2010 | Cameras
Please could you email me an instruction manual explaining all the settings and what all the symbols mean - I am very keen to progress but I need to know and understand what the camera can do - and that...
Hello Marion
OK, you will need to supply me with the model and the brand of the camera.
Once i have that information, i will be able to supply you with the manual.
Kind regards
Andrea
Sep 16, 2010 | Rollei Cameras
Hello fellas! I have Rollei digital camera, and when i plug in USB on computer it says Driver wasnt found, it worked on my old PC, help me guys please! Rollei is very good camera and i can't upload...
It sounds like you just need to go to the support site for Rollei and download the compatable driver/software for your new computers operating system.
Here is a link for the new Rollei website. I didn;t see the drivers listed but that usually means you can contact them and they should let you know where to get them. The email below that is for support.
http://www.rcp-technik.com/typo3/index.php?id=rollei_de_home&L=1
service@rollei.com
I'm not sure if you can use any other drivers but they should be able to tell you.
Aug 11, 2010 | Rollei dr5100 Digital Camera
Advent camera battery charger
ADVENT:
ADV1172E
BENQ: BENQ:
PREMIER: PREMIER:
ROLLEI: ROLLEI:
Hopefully this will broaden your options when searching for a compatable charger.
Mar 23, 2008 | Cameras
Rollei DP6200 Digital Camera Logo
Top Rollei Cameras Experts
Jax Planet
Jax Planet
james laughton
james laughton
Tony Parsons
Tony Parsons
Are you a Rollei Camera Expert? Answer questions, earn points and help others
