Question about Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR
Nikkor DX AF-S Nikkor 18-135mm 5.6G ED lens D80 Camera was dropped and now the auto focus on the lens will not stablise. The lens will manually focus and otherwise works well. About how much is it to have this function of the lens fixed. I have checked the D80 with another lens and the autofocus works correctly when using a different lens Also how long is the repair time Thank you Peter Buchan
  • 149 Answers
Problem in lens censer try to set the censer or replace it
Posted on Oct 08, 2009
  • bulkmail Jun 08, 2011
    What is the "Lens censer" ?? how can I order this part? is it any manual to replace this part?
The focus ring won't turn.
The focus ring on that lense will lock when the AF switch on the lens is on auto. Move the switch to manual and it will release the focus ring.
Sep 23, 2013 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon 18 to 55 lens wont focus
Check to make sure the manual focus/auto focus switch on the lens is set to A. Make sure the lens is completely mounted to the camera and locks securely. If this does not help, or if the lens was dropped, then you should consider buying a new lens. the cost of fixing the old lens may be at least half of the cost of buying a new one.
Nov 12, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My D80 will not auto focus with any of my 3 Nikkor lenses. It will fire on auto focus when you manually focus while in that auto focus mode.
Press the AF button on the top of the camera (to the right of the window) to select an AF mode & make sure the M/A (Manual / Auto focus) switch on the lens set to "A"
More info below:
http://www.kenrockwell.com/nikon/d80/af-settings.htm
Oct 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikkor af-s 18-200 VR not focusing
Please check your focus settings in the camera menu. Play around with the focus point from Single to 11 points. Also, try Auto mode as a quick way to test if the focus is working
Sep 26, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Auto focus at full zoom not responding Nikon D80 with 18-200mm VR
Hi - I own this lens and it manually focuses at all focal lengths (hard to see at 18mm unless your subject is extremly close). You may need to get the lens checked. BTW - Mine was set as follows when I checked for you:
  • D80 was "on"
  • M/A
  • VR = Off
  • Normal (not Active)
Hope this helps!
Apr 09, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR Logo
391 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
