Question about Eljer 111-1000-00 White Kindergarten One-Piece Round Toilet 111-1000
Water leakage from the gasket under the flapper
Nee to know solution to stop leakage possibly coming out from the gasket under the flapper.
  • 1 more comment
  • hcpatel Oct 07, 2009
    It is problem related to Eljer one piece toilet tank flush valve. I suspect that worn out gasket might be causing slow leakage, which you can see in the rim of the toilet bowl. I do not see any screw to remove flush valve part.
    It is one pice toilet and I see very slow leakage in the rim of the bowl.
  • philschneide
    philschneide May 11, 2010
    Is the leakage into the toilet bowl, or outside the toilet? Is it a one-piece or two-piece (bowl and tank) unit?
    Sniper:
  • 61 Answers
You will need to replace or repair with new gaskets your flush valve mechanism. "To do that you need to take the tank apart from the bowl. Have new toilet bolts and flush valve or flush valve gaskets at the ready when you take the tank off. (you will also have to unhook the fill valve when you take the tank off.) Another possibility would be a cracked tank that is causing the leak in that area but that is rare.
Posted on Oct 09, 2009
How do I stop water running into pan after toilet has been flushed &refilled.
If there is water still running into the toilet bowl, there is a problem with your flapper or flush valve. The most common problem, and least expensive to fix, is the flapper has gone bad and is allowing water to escape past it. Replace the flapper and the water should stop running. If not, it is possible the flush valve or one of the seals holding it to the tank has gone bad and needs replaced. Try replacing the whole flush valve. They come in a kit that includes the valve, flapper, and seals.
Feb 26, 2015 | Home
Problem with water leakage at flapper valve on eljer toilet
recheck flapper may have replaced it with wrong one
Nov 26, 2012 | Home
2003 FORD CROWN VICTORIA COOLANT RESERVOIR WILL NOT HOLD WATER WHAT ARE THE POSSIBLE SOLUTIONS
water / coolant is getting burnt in combustion chamber therefor the water loss situation. replace intake gasket and any other gaskets where visible water leakage is present. after that if problem is still there you'll be looking at getting the head gasket replaced.
Apr 17, 2012 | 2003 Ford Crown Victoria
Water keeps leaking into the bowl and runs continusly
The toilet tank valve needs adjusting for a lower water level in the tank; or the valve is faulty and needs replacing. I can't tell you how to adjust it without knowing what type you have. Many of them have a screw in the very top which when turned will change the tank water level at which the valve shuts off the water.
Charlie
Feb 23, 2011 | Eljer Toilet Onepiece Canterbury ...
Eljer runs constantly. Replaced the flapper to no avail. I can see the wate flow in on the right side of th bowl looking at the tank. Any suggestions?
The next thing for you to check is the fill valve itself, make sure it is shutting off. shut off the water to the toilet and see if the leak stops after a few minutes. it may also be a leaking gasket on the flush valve gasket. also be sure the flapper area is clean. hope this helps. let me know if you need anything else.
Jan 04, 2011 | Eljer Home
Getting water in pistons and of course oil.Is it
There are Flapper plates in the exhaust. They can burn out especially when running with the Muffs for winterizing. Then problems shows up first time you take it out. Usually this problem does not show while boat is moving. The bad flapper allows water to draw up into the engine like having a straw in a drink.
Sometimes when decellerating or Transom to the waves a rush of water goes past failed Flapper and into engine. Instant Hydro lock.
Its easier to change the Flapper than removing a head and you know which exhaust to target. When you get the Flapper out, the parts guys can easily tell you if its junk.
May 10, 2010 | Boating
Toto flapper seems ok but toilet keeps slow trickle into the bowl
The water inlet valve should close completely and stop water from coming into the tank before the water level reaches the "small tube." (This is the overflow tube.)
There may be an o-ring or rubber gasket inside the valve that can be replaced. If not, you would have to replace the water inlet valve.
Oct 16, 2009 | Home
Small streams of H2O down interior sides of commode bowl. Have replaced flapper and color tested for leakage,Nada, replaced ballcock fill assembly with Fluidmaster unit and still getting very small...
this is still the flapper.each toilet has a flapper designed to fit each toilet.your may not have the right flapper for the toilet you have.not all flappers weights are the same.youmay need to add some weight to the flapper or replace it with one that is designed for that model toilet.good luck with your project
Sep 29, 2009 | Home
Water leaks from tank to bowl till water level in the tank is jus
Yes. You will have to remove your tank from the bowl to replace the defective fill stack(the tube thing your flapper is attached to) it is not as hard as it seems.First remove water supply tube.Then remove the through the tank bolts. should be two of them. Lift off and turn tank upside down. remove spud gasket. Unscrew old stack. You should be able to get a universal kit to work with your tank and should come with all new parts including new flapper and spud gasket. You will need new through the tank bolts and note the sequence of assembly to get water tight seal on tank. Hope this helps
Aug 03, 2009 | American Standard 2002.014 - Champion4...
Eljer 111-1000-00 White Kindergarten One-Piece Round Toilet 111-1000 Logo
223 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
