Home | Shredders | Royal ORCA 3500 pap...
Shredders
Problem for Shredders
Generic problem for all Shredders
Royal ORCA 3500 paper shredder
By momentum4 on Dec 24, 2007
Before I begin describing my dilema, is there a fee for using this chat site for repair advice?
Same Problem
Feb 26, 2009
-   I had a similar problem after a few years of relatively light use. The problem was with one of the main gears in the gear box. The counter bore in it's guide bushing wore out and elongated allowing the gear to slip. I pulled apart the assembly, removed and re-installed the bushing rotating it 180 degrees. It was working fine for a whlie but the same problem is showing up again.
I think this guide bushing needs to be made of a more durable mateial. -   Guest
Feb 02, 2009
-   orca 3500: reverse works but auto run does not. Green Light is on, bin is empty but will not shred paper? Any suggestions? -   ram1818
Best Solution
posted on Feb 01, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Popular Solutions for Shredders
Questions and Unsolved Problems for Shredders
Answer
I have a Novitech PS-026/B2 shredder. It will run in reverse, but will not shred. I tried compressed... (More)
Answer
I have a DAHLE 507 personal trimmer and I have lost the plastic end cap which keeps the cutter bar... (More)
Answer
My Texet CC11L shredder has stopped working, after too much 'soft' paper, possibly including... (More)
Answer
need drive gear for staples shreadder spl-826x. Thanks
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Shredders:
Top Shredder Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Shredder Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
